Question about NorStar T7316E Corded Phone
Nortel T7316E Voicemail
I've just moved into new offices where they have a Nortel system. I've recorded my voicemail but cannot activate it. The phone is on a loop with another handset and they just keep hopping from one to the other.
Please help
  • ynotphone
    ynotphone May 11, 2010
    Sounds like the Forward No Answer -or- Forward on Busy has been enabled to each others sets...
    do you know how to get into system programming?
  • 27 Answers
It sounds like both phones are set to ring on incoming calls and both phones are set to call forward to voice mail box with the same amount of rings . you should turn off the ringing for both phones that way it will not jump between the to mail boxes . now when a call is trans it will go to the box .
Posted on Aug 15, 2009
SOURCE:
  • 537 Answers
SOURCE: Changing MAIN voicemail announcement
I am not a phone installer and we have another vendors' phone system here at our work.
It can be *extremely* difficult setting up these phone systems, even with a manual.
Here is one such link that might help:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Here is another forum that has lots of friendly folks that might be able to help
http://www.sundance-communications.com/forum/ultimatebb.php?/ubb/forum/f/8.html
You will get an answer much sooner on there than here probably.
Mike
Posted on Nov 09, 2007
SOURCE: changing name in nortel T7316E handset
instructions are toward the bottom of this page:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Posted on Aug 26, 2008
SOURCE: how do i inrease the number of rings
Don't know if this will work, but try the 983 feature, pw 1020000 (or 120000, or 10020000, depending on your extension numbering). Access the Mailbox menu. "Show" thru the menu until you get to "forward to" ###, then next. This should ask for delay. (to est time in seconds, multiply the number of rings by 6)
Posted on Jan 02, 2009
ynotphone
  • 192 Answers
SOURCE: change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
Posted on Mar 19, 2009
  • 52 Answers
SOURCE: Nortel Voicemail Reset Password Problem
You have to make sure this is the wright mail box for that local The mail box should be the same as the local.From the main set press feature 983 password
120000 for 2 digit locals , 1020000 for 3 digit locals etc then press mbox press chg enter mbox no. next password press reset this will take in back to 0000 as mailbox password.
Posted on Nov 27, 2009
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
Why a blinking red light Radio Shack 5.8 GHZ 43-5560 phone
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jul 03, 2013 | Nortel T7316E 2-Line Corded Phone
HOW TO SET UP DIALING TO OFFICE EMPLOYEE AFTER VOICEMAIL GREETING ON MY T7316E
This is the most complicated part of the Norstar voice mail system and requires a tech or fully trained admin at site.
It is called CCR Custom Called Routing.
You need to record "thank you for calling ABC" under AA/GTG/GTG/1
You then need to build a CCR tree and record the rwst of the greeting under Path 0.
Path 1 , 2 etc is where you do the pointing.
There is too much to mention here that needs to be done.
Norstar System Coordinator guide (for any version) is your friend as well but a 2 hour service call is well worth the headache.
Aug 06, 2012 | Nortel T7316E 2-Line Corded Phone
F 981
If none of your voicemail feature codes(f980-f989) are active, then that means that the system doesn't recognize any nortel voicemail on the system.Which means that a) your system has a non-nortel voicemail system attached to it, b) theres no voicemail attached to the system at all or c) the voicemail is no longer functioning.
Jun 23, 2010 | NorStar Meridian M7310 Phone
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
How to get voicemail from another phone nortel 7316e I am trying to get my office messaged from my cell.
If your trying to get your messages from another nortel set in the office press your open voicemail button or feature 981. The left soft key below the screen should say OTHR. press the soft key the screen should change to LOG: enter in the mailbox number followed by the password and #.
If your trying to get your messages remotely, call into the office and when the auto attendant answers, press ** followed by your mailbox number password and #.
Nov 02, 2009 | Nortel T7316E 2-Line Corded Phone
Voicemail and password
I would unplug power to the voicemail, then restore. Wait 10 minutes and then do the same to the phone system.
What you are trying to do is reinitialize the voiecmail, if you dont know what you are doing you will do more harm than good.
Jul 20, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel T7316e help
dial your voicemail, put in your password, after you are in the voicemail, press 8 and listen to the prompts, it will tell you were to record your name for the company directory.
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
Need to listen to office voicemail from home
Dial ** when your voicemail answers. Follow prompts.
Dec 19, 2008 | Nortel T7316E 2-Line Corded Phone
NorStar T7316E Corded Phone Logo
1,218 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
