Not getting incoming calls
SOURCE: What is the default password for micromax x2i
The Keypad Lock Icon is seen on top of the screen at various positions depending on the number of icons displayed. An Open Lock signifies that the phone’s keypad is unlocked and a closed lock signifies that the keypad is locked. You can unlock the keypad by pressing Unlock (by right soft key) on the phone, followed by the Send (GREEN) key. Similarly for locking the keypad, press the End (RED) key, to be followed by the Send key.
The user guide for your phone does not indicate a default pass code. Most default passcodes are either 5 or 6 zeros. Some are 12345.
See user guide:
http://www.micromaxinfo.com/downloads/guide/X2i_UM.pdf
SOURCE: Hi My mobile call barring password blocked.How can I unblock it
if you forget the pass,then you must format your phone by : 1. Backup your data in your phone first. 2. Make sure your battery is fully charged. 3. In off condition, keep holding " * "," 3 ", and "Green/Call" button and turn it on. remember to keep the three buttons pressed until the "Formatting" screen show up. the security code on your phone will be reseted to default "12345",along with factory default. that's mean, remove your call baring too. sorry, this is the only way i know. maybe other experts know the better way? just use this method as your last resort :) regards
SOURCE: What is the default password for micromax x211
The default password of micromax
x211 is-----1122
SOURCE: default password for spice mobile
spice m-4580 phone incomingcall onering and phone will be buse
You can bar the calls that can be made
or received with the device (network
Make calls 35
© 2010 Nokia. All rights reserved.
service). To modify the settings, you
need the barring password from your
service provider. Call barring affects all
call types.
Select from the following voice call
barring settings:
Outgoing calls - Prevent making
voice calls with your device.
Incoming calls - Prevent incoming
calls.
International calls - Prevent calling
to foreign countries or regions.
Incoming calls when roaming
- Prevent incoming calls when outside
your home country.
International calls except to home
country - Prevent calls to foreign
countries or regions, but allow calls to
your home country.
To check the status of voice call barrings,
select the barring option and
Options > Check status.
To deactivate all voice call barrings,
select a barring option and Options >
Deactivate all barrings.
To change the password used for
barring voice, fax, and data calls, select
Options > Edit barring password.
Enter the current code, then the new
code twice. The barring password must
be four digits long. For details, contact
your service provider.
hope this helps
John
