Question about Watches
I pulled on the crown and it came off the stem
I have an old tag heuer proffessional 1000 i think from 1970 and i pulled out on the stem and the crown came off. dont know if it is broken or the crown will screw back on or is the stem pressed in the crown.will i have to open the watch to get the stem back out?
  • Anonymous Mar 14, 2014
    remove stem crown
  • 2,338 Answers
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Posted on Mar 24, 2009
  • David Sulliban Apr 26, 2012
    I have the Timex Expedition E-Compass. The crown still has the broken stem inside and I do not know how to remove the stem from the main watch. Can you help?
SOURCE:
If the stem does not lock in, will it still be waterproof?
You need to get out your jeweler's loupe (best at 5x & 10x)... and look for the threads to "*****" (ski-rue) down your winder-stem (not a lock).
(Features a Ski-rue down crown & back case)
YOU can pretty much be assured that if the "stem" collar is malfunctioning (broken) the "water-proof" element is compromised (that's most likely the least of your troubles).
More importantly... if the STEM does not properly "tighten" it can
cause further damage against gears which MUST align with it... further it can come all the way out and be lost... Not an inexpensive part.
Best direction would be to get it serviced by an authorized agent.
TAG Heuer Aquaracer 500M Quartz Mens Watch WAJ1110 BA0870
TAG Heuer Aquaracer WAJ1110 BA0870
Jaxa style Suissetek XL Wrench Case Opener for Large Screwback Watches
Mar 30, 2016 | Tag Heuer Aquaracer Quartz WAJ1110.BA0871...
How do i remove crown?
hummmmmmm
u need to go experts of watch reper i think its its problem in watch curcuit thats y this happen
& thnx useing fixya
Mar 28, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    I want to know how to change the clock. Tag Heuer 2000 Classic Silver Dial Steel WK1312-0
    Hi! your watch probably has a screw down crown which is a feature found in well made watches. Turn the setting mechanism on the watch until it unscrews then pops out a little , pull it out two clicks to set your time, and one click to set your date. The one click setting can tricky it is what we call a halfway setting but you will feel it pulling the stem in and out. Then make sure to screw the crown back in this is a water resistant feature. Thank you! hope this helps:)
    Sep 06, 2011 | Tag Heuer Watches
    How do i reset my tag hauer? I can't seem to pull out the crown.
    It may have a screw down crown. Try turning the crown counterclockwise see if it unscrews. There is no other reason for it not to pull out unless someone has opened the back and removed the crown and stem then inserted it crooked and it is stuck.
    If someone has done this the watch could be damaged.
    Nov 07, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
    The stem broke off of carrera watch. How much should repair for this problem be?
    mcdevito75 here, A new stem and crown Approx. for your Tag Heuer, $125.00 that"s if the stem is broken, if the stem just pulled out it may be able to be saved. Check here at fixya, bottom of page, click on repair service directory the watches.
    Jul 03, 2010 | Tag Heuer Automatic Chronograph Series...
    I cant set the time.
    sounds like the crown stem may have snapped. Same happened to me and it had to be replaced at a cost of NZD$300. Have you bumped the watch or maybe tighted the stem too tight?
    May 14, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
    How can i make the date of my tag heuer formula 1 change automaticaly?
    To s e t t h e t i m e a n d d a t e
    Your TAG Heuer chronograph is fitted
    with a screw-in crown and safety seals
    which guarantee it to be waterproof
    to 200 m (660 ft).
    Position 0: Crown is screwed in
    (normal position).
    Important: The crown must be
    screwed in correctly to guarantee
    the water-resistance of the watch.
    Position 1: Crown unscrewed.
    To change the hour (change of time
    zone) or date quickly, unscrew the
    crown, pull it out to position 2 (quick
    corrector) and turn it in either
    direction. This mode allows you to
    change the hour and the date without
    any loss of minutes.
    The date changes each time the
    hour-hand passes midnight.
    To set the time, unscrew the crown,
    pull it out to position 3 (setting the
    time) and turn it in either direction.
    After setting the date or the
    time, push the crown back and
    screw in to position 0.
    Oct 10, 2009 | Tag Heuer Formula One
    Help setting the time
    Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
    Nov 06, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
    Removing the crown
    The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now like your Tag Heuer is pushing, use a needle to push, while pushing the stem lock you pull the crown .That's why ill tell you in advance so you aware.I know because i'm a watch technician working in rolex before...
    remove the crown
    if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
    Regards,
    VOTIT
    Sep 07, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
    Watches Logo
    1,340 people viewed this question
    Top Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
