Nokia 1100 Logo
Posted on Aug 21, 2007
Battery my battery is BL-5C and serial number is 0670400462040 can u check this battery plz thx
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Aug 27, 2007
Anonymous
Contributor
Level 1:
Answers
27
Questions
Helped
5435
Points
53
Its not need to chack just go to u r nearest any mobile shop or where from u buy it and show them they will change it
tip
How to put higher capacity battery into old Nokia Mobile Phones
As we all want longer stand-by and talking times with our mobile phones and sometimes get problems to get an original battery for our old Nokias, here is a tip for this matter:
Most of the former Nokia mobile phones use the battery with the model type number "BL-4C". There are some models using type "BL-5C". This "5C" model has more capacity and could also be used instead of the "4C" model. The 5C model is slightly fatter than the 4C one.
Using BL-5C needs with some Nokia mobile phone models a little modification (like 6100) while others do not (like 6260) and require a bit harder close of the battery lid. Cutting both edges on the batteries sides to fitting in the battery compartment is easy done. Charging process is not influenced and works accurate.
on Feb 28, 2011 • Cell Phones
Charging not support
HI..first check the battery,,Clean the battery connector...Or insert another battery of different number.(if it is BL-5C insert BL-4c)...If the problem persist follow the image.According to the image just remove the indicated components.Good lcuk7_5_2012_4_09_10_am.jpg
Nokia 6233 charger not supported
Before you contact mobile repairing shop.check the battery because nokia battery BL-5CA and BL-5C are different.So, if the current battery is BL-5CA insert BL-5C, and follow as vise-versa.Otherwise contact mobile repairing shop.Thanks for visiting fixya
Sir my nokia 6300 have problm charger not spourted plz send me best sloution thanks
every cellphone has its standard battery... in nokia6300, the standard battery is BL-5C.... if you inserted it with different battery type... thats the result "charger not supported" in most cases.... or you are not using a standard charger.. check it out...
1helpful
Low battery
sir the nokia n70 comes with BL-5C battery this batter has a complaint it will not cover 1 year lifetime. so the best way is to buy a new BL-5C battery and charge it initially for 8 hours continuously..
About nokia battery BL-5C
Please contact nokia care service center.
Jan 15, 2009 • Nokia 1100
Battery
i have nokia 7610 but gosh mya battery easily get drained, it tooks 3 hrs of use ,im using the correct battery -5c something like that,, pls help me find the solution
6helpful
5answers
Regarding BL-5C battery blast
Here's the list of phones that should replace their batteries Nokia 1100, Nokia 1100c, Nokia 1101, Nokia 1108, Nokia 1110, Nokia 1112, Nokia 1255, Nokia 1315, Nokia 1600, Nokia 2112, Nokia 2118, Nokia 2255, Nokia 2272, Nokia 2275, Nokia 2300, Nokia 2300c, Nokia 2310, Nokia 2355, Nokia 2600, Nokia 2610, Nokia 2610b, Nokia 2626, Nokia 3100, Nokia 3105, Nokia 3120, Nokia 3125, Nokia 6030, Nokia 6085, Nokia 6086, Nokia 6108, Nokia 6175i, Nokia 6178i, Nokia 6230, Nokia 6230i, Nokia 6270, Nokia 6600, Nokia 6620, Nokia 6630, Nokia 6631, Nokia 6670, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 6820, Nokia 6822, Nokia 7610, Nokia N70, Nokia N71, Nokia N72, Nokia N91, Nokia E50, Nokia E60 The battery name is BL-5C
Aug 15, 2007 • Nokia 1100
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
