My Monitor flickers, freezes and goes black...
It freezes from time to time it includes the mouse cursor and keyboard.
The screen goes black for a second or two then comes back even if it is running and turned on.Meaning the light is yellow not red signaling that it is on. Normally you only get black screen when it is off and the light is red.
It's really annoying and gives me a hard time...
I'm not sure if it has something to do with the motherboard or what that causes the problem.
Please I'm badly in need of help.I don't have much resource and money to buy a new one or whatever.
Thanks to whomever will help...
Have you tried to check if your pc is infected by virus? you should update your anit virus.
try to check the power option. check if the hibernate option is disable.
will have to take this step by step so that we can identify where is the problem. make sure that hibernate option in power mode is disabled.then try if it is still the same.and then will go from there ok.
ok. can you please disabled it first before we move on.after disabling try again to observed what will happen.you need patience here my dear.we need to see what happen first.if it is still the same or not.
under power option you can see below the option power saver, "turn off the display" make the option to never.
we need to check it first in your software before we go on to your hardware.after the software is done and it is still the same, this is the time we are going to troubleshoot your hardware ok.
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens.
Type "Cursor blink" in the "Search programs and file" text box.
A list opens.
Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens.
Click the "Speed" tab. A list of options appears.
The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast."
Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale.
Click "Apply."
Click "OK." The cursor stops flickering on the screen.
hope this helps
Nah!I have an updated ZA securuty suite....I have tried scanning and all but it's still busted..Please help
then what will I do next?And is there any other ways in case this
doesn't work either? Because as far as I know this whole problem was
very sudden... Everything run well then it became like this...
I'm using the hibernate option and it was long turned ON even before I had this problem....
I've already done what you've said but it's still the same...actually the monitor is on indicating the green light but it turns black for a second or two from time to time...
I'm really havin a hard time....PLease help....I'm sorry if I'm not that patient....
NEED HELP!!!
