I have a 1993 murray lawn tractor 12.5hp brigs&stratton ic engine with a 4 position (off, on/headlights, on, start) ignition switch, It has 6 terminals on the back The only replacement I can find is a 3 position (off, on, start) with 6 terminals. I'm trying to find a wiring diagram for the mower to decipher the difference in the placement of the wires on the 2 switches. I don't care about the headlights. I just can't figure out the alternator and kill wires, because this is magneto ignition. Any help would be appreciated.
Thanks for your time
Jack
SOURCE: 4 cycle, 5hp briggs and stratton, lawn mower
Try taking off the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs on the magneto. Also clean the end of the spark plug wire. I use fine sand paper or emery cloth.
Good luck and let me know if this helps.
thanks roundo4
SOURCE: craftsman 22hp lawn tractor when its hot i loose
not a expert just trying to help,, sounds like you have heat problem with the carb or the fuel line,,make sure all the heat sheids are there,, if not repllace them,,cause it will cause the gas to try to vapor lock. hope this help you
