My printer showing an Error code 21.1:03 Restart the printer. If the problem persists call HP support. Can you tell me the solutions?
SOURCE: My hp leser jet 2420 printer shows me an error
look here:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1245403811282+28353475&threadId=74920
and this:
power on your printer, after you see processing data the second time, press cancel.
Everytime I have seen this error is because the user tries to print a PDF file that is corrupt.
This has worked for me in the past.
SOURCE: error message 0x610000f6 won't re-set.
>try to do hardware reset
>while printer is on unplug power cord at the back of it, press and hold # and 6 buttons on your printer, while holding the buttons plug back power cord, printer should initialise you can release the buttons after 10 secs or until you see semi full reset on the display, if the printer will not automatically turn back on press the power button, if it ask for you to set the region and laguage again then you have done the reset successfully
>this hardware reset should clear the error otherwise better contact hp
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
SOURCE: my hp printer m1005 show
A 20 error is insufficient memory.
The device received more data than can fit
in the available memory. You might have
tried to transfer too many macros, soft
fonts, or complex graphics.
Touch OK to print the transferred data
(some data might be lost), and then simplify
the print job or install additional memory.
As for the 17 error?...I can't find it in the manual.
The Problem keeps on coming on the screen "Restart the printer, if the problem persists, call HP Support" how do i solve the problem?
