SOURCE: kodak i1440 scanner error 4769
Hi the error isnt one that corresponds to a scanner error number , you should run the scan validation tool and get the error from that , having said that check the image guides are clean and undamaged this is a major cause of faults
SOURCE: Hello, My Kodak i1440 scanner is
First you need to see if the scanner shows in the device manager , if it doesnt it is likely the CPU / Main board is faulty If you can see the scanner in the device manager it has connected and loaded its firmware in this case it could be many things but the image guides are the most common issue , check them for damage especially the white area on the underside
