Frigidaire Model FEFLM605DCC in black.....do I replace and how? How much will this cost me?
SOURCE: Front burner won't ignite when turned on.
Hello there:
if you Heard or seen this poping you probably have shorted out the ignitor mechanism You can try unplugginh the stove and removing the part and inspecting it and see if it can be cleaned and doubkle check the wiring to see ithatthey are not greasy or there is any buiold up on the wires then reinsert the part and see if it will work now but if not you will have to replave the ignitor ok
If you have a local appliance repair center you should be able to get the part from there if not go online and go to www.repair clinic.com youcan order it from them ok
Hope this is very helpful for you
Best regards MIchael
Testimonial: "Thank you so much for your help.I am definitely going to take your advice. Working on it right now. Much appreciated."
Hello friend, thank you for your post!
I understand that you are searching for the wattage on your Frigidaire range. In order to provide you more information I would need to have your model number. You can locate your serial tag (which lists your model number) on the outside of your cooktop base possibly on the edge or bottom under the unit. Once I have that information I can further assist you. I look forward to your response. -Matt
