SOURCE: indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
SOURCE: flashing lights indesit wil103
you will need to unplug the machine at the mains, give it two minutes and the auto door lock will release your duvet, however start saving the pennies as your pcb is knackered and you'll be looking at about £200 to fix it
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
SOURCE: I have got Indesit WIXL 123 washing machine. Until
i had the same problem its the motor you need a new one luckly my father inlaw is a scrap collector and i come across a spare washer and salvaged all the parts and i tried plugging a new circuit board but still the same so i tried changing the door lock mechanisim but still the same, so itried just for the hell of it the motor and weyhey we have life i thought the motor was the most unlikely thing to cause the problem but im happy but for how long? next year will replace it with new washer.
