Our bathroom has shower & tub plumbing that we can't identify to replace the spigots & handles. Was told at a store that we have to replace the parts w same brand but don't have any brand identifiers. Do we have to replace everything? TY in advance!
SOURCE: 1 HANDLE TUB/SHOWER. WHEN YOU TURN THE SHOWER ON
The diverter is worn and needs to be replaced.
The diverter is the lever/button you pull/push to switch from shower to tub. When they get worn, they require more pressure to seal properly and divert the flow.
SOURCE: I have a Moen shower tub single handle from the
I took the parts to the Menards in town. Luckily I found the guy that knows it all! He showed me the rubber gasket( that holds the ball) to purchase as well as recommended that the 2 small rubber gaskets that were in there to be replaced as well while I had it open to avoid doing this in the future. I got home and replaced them and no leaks:) Thanks:)
SOURCE: moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
SOURCE: replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
SOURCE: need shower door replacements parts
Supplier in the Netherlands, www.novellini.nl
For the 30095PPC are the next parts:
De benodigde artikelnummers zijn:
1 x R02YOB2G-40 (set scharnieren t.b.v. één deur) à € 23,80 incl. btw.
De prijs van de bovenstaande set onderdelen is € 23,80 incl. btw.
Verzendkosten zijn € 7,50 incl. btw.
