VCR ONLY USE 5 OR 6 TIMES SINCE PURCHASE 20 YEARS AGO-AND ONLY FOR CASSETTE PLAYBACK (NO RECORDING). NOW NO PICTURE NOR AUDIO EVEN WHEN CONNECTED DIRECTLY TO TV (NO ANTENA NOR CABLE). TRIED HOOKUP ON 2 DIFFERENT TV'S WITH NO DIFFERENCE..ONLY 'BLUE'SCREEN AND ABILITY TO SHOW 'DATA SCREEN'. INSIDE OF UNIT LOOKS SUPER CLEAN AND MECHANISMS WORK OK. I NOTICE THAT UNIT DOES NOT APPEAR TO RECOGNIZE HOW MUCH RECORDING TIME REMAINING NOR ORIGINAL MINUTES AND COUNTER DOES NOT COUNT DOWN MINUTES PLAYED...'AUTOTRACKING'INDICATOR FLICKERS ALL THE TIME RATHER THAN STAY ON STEADY ?.....ANY SUGGESTIONS WOULD BE APPRECIATED...jim
SOURCE: CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
Solution #2
posted on Feb 09, 2008
jdrrwoods
Rank: Wiz
Rating: 84%, 12 votes
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
SOURCE: playback problems - timer stays at zero
mi proble is: the power is gone, no power in the camara
please giveme a solution att. norman mejia
group A 893
group B 5889
group C 511833
val # 0294-2802-9294-4641
I
SOURCE: PV-GS9 mini dv playback problem
I covered several threads that recommended buying a Mini DV cleaner and
running it up to 4 times. They also suggested to change to change your
video tape as it may have been the cause of the original problem.
These
solutions may have worked for many but not me. My camera was becoming
progressively worse. It went to blue bars and no sound to no picture at
all...just blue. After using a cleaner 4 times I became frustrated to
the point I was going to buy a new camera.
However, with the
camera still playing, I did the typical guy thing and rolled up my fist
and gave it a good hit along side of it. Remarkably it went back to
just the blue bars. I hit it again and it went back to a perfect
picture. I'm not saying this will work for you and hitting it too hard
could make things worse but I was at a point where I didn't care any
more and took a chance that paid off.
SOURCE: Picture rolls on playback
I beg to differ that the head is dirty. This is based on your post "...pre recorded tape is played the picture is fine..."
I am more inclined to suspect:
Hope this be of initial help/idea. Pls post back what is your video source, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
