Have no problem transferring from camera to computer HOWEVER these pictures files are so much bigger than my other camera!! I just emailed 2 vaca pics = 17599KB. I looked at my other pic files & sent myself 2 vaca pics = 3567KB. why the huge size difference?????
SOURCE: coolpix s220 won't transfer pics via usb cable
If you can get the pics using a card reader, why are you insisting on using the camera and USB cord? Pros always use a card reader.
SOURCE: Transferring pictures from computer to camera
Hi Mike. The only way I can think to do this, is with an separate card reader. Then you could take your SD card and load back and forth, from your computer to camera (and vice versa).
hope this helps!
SOURCE: need to know how to transfer pics back to camera
From your computer "to" the camera? This seems backwards but you would pop the SD card out and put it in a card reader (your USB cable might work too) and copy the files using My Computer. the camera will appear in My Comuter as a drive letter.
SOURCE: pictures will not transfer off the camera
Here's a silly suggestion for you... is the "lock" engaged on your memory card? It will be a small sliding lock portion on the SD card. If yes, unlock it and try again.
SOURCE: Macbook says file type "unrecognizable" from Kodak M763
It seems that your computer doesnt recognize jpeg files . Download or reinstall quicktime to fix the problem, you can get free download at www.apple.com
