Question about Haier Refrigerators
Refrigerator serial number location - Haier Refrigerators
2 Suggested Answers
6ya staff
SOURCE:
peyton32034
peyton thompson
  • 410 Answers
SOURCE: serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Posted on Jan 27, 2009
Where is serial number on 241982121?
Good Morning Friend, that's a great question!
In order to provide you the correct serial number of your Frigidaire refrigerator, I would need your model number please. The serial tag, which lists your model number, is typically located inside the cabinet, on the left/right side wall. Thank you and I look forward to hearing from you! - Z
Sep 04, 2014 | Frigidaire Refrigerators
Find a serial number
To find the serial number, if not in obvious location such as on the door itself, somewhat like on a car, you will probably have to pull the unit out from the wall, remove the back panel, which involves a considerable effort, and look for a serial number inside. There may be a separate serial number for the compressor/motor and for the refrigerator itself, as the compressor/motor may have been supplied by a subcontractor to GE such as Copeland or Temcuseh although GE did build their own I just don't know offhand in your case.
Mar 28, 2014 | GE Refrigerators
FRIGIDAIRE SERIAL NUMBER LOCATION REFRIGERATOR
Typically the serial tag, white or silver sticker label, is on the inside of the refrigerator wall cabinet. My experience is you will find it on the left hand side, by the top shelf.
Jul 18, 2012 | Frigidaire Refrigerators
I just bought a Bosch Linea B22CS80SNS. Where is the serial number located? Thanks much
The serial number is located on the inside of the refrigerator section, on the right side of the first vegetable bin on the panel.
Aug 29, 2011 | Bosch B22CS80SNS (220 cu ft) Side by Side...
I am needing to find the serial number for fridge model number LBN20518ST
The serial number should be located inside the refrigerator section on the right wall. If not there, look on the right side of the refrigerator or in the back. The serial number is usually 3 numbers followed by 4 letters and then 5 more numbers.
Good luck
Jun 15, 2011 | LG Refrigerators
I have a Maytag MSD2758GE side by side refrigerator/freezer whose thermostat/defrost assembly has gone bad. Obviously the freezer has iced up and isn't working properly, but would that effect the...
sounds like you need to replace the adaptive defrost assembly. and yes, it will effect the performance of the fridge. the part number is 12002104 if the first 2 numbers of your serial # is 22; or 61003990 if the 1st 2 numbers of your serial # is 10; or 61005988 if the 1st 2 numbers of your serial # is 17. here is a breakdown showing the location it is # 13 in the picture. hope this helps.250
Nov 07, 2009 | Maytag MSD2758GEB Side by Side...
SERIAL NUMBER UN-READABLE ON MAYTAG REFRIGERATOR MODEL #MTB2456AEW. NEED SERIAL NUMBER FOR PART REPLACEMENT. ANY SERIAL NUMBER FOR THAT MODEL WILL DO. THANK YOU. AL. M
Al have you tried the appliancefactoryparts.com site to locate the parts you need, at that site you only need the make and model to access the parts list
Jul 30, 2009 | Refrigerators
Serial number
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
165 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
