Question about Haier Refrigerators
Refrigerator freezes water and cola drinks inside it
I have a Haier refrigerator, Model HNSE55SS and no matter how low I set it to it keeps freezing up water in bottles and colas in cans that I place in it. I set it down to 1 and it froze these items and then I set it below 1 and it still freezes up these cans and bottles. Awhile back this was happening but my plastic freezer door had broken off so I attributed this situation of freezing drinks to the broken freezer compartment door but that little door has been replaced and these drinks are still freezing. What could be causing this and what can I do to correct it? Thanks! God Bless!
    Top Expert:
  • Haier Master
  • 53,746 Answers
Have the thermostat checked as it appears that it has stopped controlling the temperature you set to
Posted on Jun 16, 2013
SOURCE:
  • 31 Answers
SOURCE: Whirlpool refrigerator Model # ETIRHMXKT
can be worn gaskets...clogged pipes or coolant leakage.
tell me about
Posted on Jun 22, 2008
dykaar
  • 6 Answers
SOURCE: Sub Zero model 550 bottom
My Subzero 550 did this: The right side of the freezer has a drain that was plugged with ice. When the freezer defrosts the water runs down the inside of the box and onto the drawer rails, where it then freezes. The drain tube is normally kept ice free by an aluminum strap wrapped around the copper defrost tube in the freezer heat exchanger, which runs down into the drain tube. Over time the copper defrost tube gets some surface corrosion and the aluminum strap doesn't get warm enough during the defrost cycle to melt ice in the tube. If you can get it apart, you can clean up the tub surface with steel wool, or buy the electric defroster for the drain tube to replace the aluminum strap.
Posted on Oct 21, 2008
  • 121 Answers
SOURCE: GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Posted on Nov 30, 2008
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
  • 116 Answers
SOURCE: Frigidaire Refrigerator FRS26H5ASB5 side-by-side
Hi, yes, your thermostat could be faulty, yes there should vent( damper), check controls on freezer side, controls amount of cold air going to ref. side, yes could be stuck by ice, yes both adjustment are necessary, check manual, some thermostat are very sensitive, you should adjust gradually, wait for about 40 minutes, before adjusting again. yes there's vent flap (damper) yes that could be your problem, normally they get stuck with ice, remove covers to locate it., you 're smart, you will see, damper, good luck.
Posted on Aug 12, 2009
Freezing milk and water bottles on top shelve
Defective temperature sensor in the fridge section.
Aug 30, 2016 | Frigidaire Refrigerators
Is freezing water in a plastic bottle harmful to your health?
Yes, but not as harmful as heating water in a plastic bottle.
Aug 29, 2014 | Refrigerators
Sanyo Mini Fridge Freezes Everything
For me I think you have a problem in Thermostat switch contact. Or the rotary switch was not in good contact point, better check it and if still the same, proceed to check your thermocouple if functioning.
Jul 22, 2013 | Sanyo 2.4 Cu. Ft. Compact Mid-Size...
Deep freezer not freezing food and keeps making a clicking sound.
Even a sealed unit could need recharging with R134a refrigerant.
Dec 29, 2017 | Haier Refrigerators
My Haier mini fridge (model # HSW02C) is freezing everything in it's contents no matter what number setting (1-7) it's on. Is 1 supposed to be the coldest setting, or is 7? What should I do?
Hello
Number 1 may be the warmest.Set it to 2 or 3 and give it some time,a couple of hours to level out.
If this does not work try a higher number.
If still no luck then the thermostat or sensing bulb is bad and should be replaced.
Mar 24, 2011 | Haier Refrigerators
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Aug 22, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
It's spitting ice crystals when turned on, and is very noisy.
I'm in a similar situation with a physical neccessity for a/c, year round, even though I live in temperate New Jersey. My husband is an A/C / Refrigeration tech & here's some things you can try to fix your Haier A/C.
1.) Make sure you keep the area where the filter is clean, if you aren't using a filter, you are clogging the air flow much quicker, which can lead to freeze ups.
2.) Due to how shoddy things are made now-a-days & with the storm coming through, you may have a conked out compressor or may have a small refrigeration leak, which can also cause freeze ups.
3.) Make darned sure that the unit is level, if you find it is not, leave your unit off for at least 24 hours for the refrigeration gas & oil in the system to level off.
Sadly, I do not know the model or type of Haier A/C you have & as I'd mentioned, things are no longer made to last like they once were & to get 3 years from a newer model is likely to be the best you can hope for. Haier is fairly decent with wanting to keep up customer morale & if it's a newer unit (younger than 18 months), they may help you to repair it for free or low cost. Good luck with that!
Aug 06, 2008 | Haier HPAC99ER Air Conditioner
Refrigerators Logo
151 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
