Computers & Internet Logo
Anonymous Posted on Mar 23, 2009
HP 1702 Monitor comes on but immediately goes off.
Hp 1702 monitor when turned on, the power light come on for 2 seconds and then go off. About every five seconds the light will blink and you can see the image on the screen for about a second and it goes off again. This happens over and over again.
Anonymous
Level 3:
  • Master 748 Answers
  • Posted on Mar 23, 2009
Anonymous
Master
Level 3:
Answers
748
Questions
Helped
289929
Points
2405
There are five capacitors on the power board which have dried out and need replacement. A reputable repair shop should be able to fix this for around $50.00 including labor.
Monitor goes dark after about 2 seconds
I have the same monitor, its a power supply problem from the computer most likely. check the cable connections etc... I would get a service call from an authorized dealer near you ... about $120.00. Hope this helps:)
2answers
Hp 1702 monitor comes on a few seconds then shuts off
1. your monitor has a power supply problem and will have to be serviced by a monitor tech.
the input regulator for the DC (Direct current is faulty and needs replacement as well as one or several capacitors related to the input circuit.
1helpful
15" HP Pav. monitor turns on for a second but immed blacks out
Pls ask your dealer about the warranty..It depends as per the market.. If the light is comming then replace the AD card other wise The problem with the inverter card.. replace ...
No power to moniter
This kind of problem needs an isolation. Please try the steps below:
1. Check the physical connection and make sure that the power cable is properly seated to the monitor.
2. Connect the monitor into different power outlet.
3. Try using different power cable.
Otherwise, you need to bring your monitor to the repair shop if none of the steps help.
Have a great day!
11helpful
2answers
After hooking up this monitor,the 1702 goes
Hi Don,
it sounds like your monitor's Capacitors have gone bad. This is very common. It is repairable, but the caps have to be removed and new ones resoldered on.
If you have soldering skills, not too tough of a job. If not, a shop will usually charge around $100 or so. You will have to weigh the cost vs a new monitor on this one.
Here is some more info for you on the Capacitor plague, that is quite common on monitors now.
http://en.wikipedia.org/wiki/Capacitor_plague
3helpful
2answers
HP monitor vs17 goes black with power light flashing
I have repaired an HP 1702 monitor that had similar symptoms by replacing the capacitors on the power supply board but you have to have some electronic knowledge and do some soldering if you can buy the replacement capacitors($10+/-) from a supply store. They (at least 1) will be swollen up on the ends and may have a tar-like substance leaking from them. It is best to replace them all (may be 4 depending on the model).
HP 1702 won't power up
http://mcmelectronics.com/browse/Capacitors/3829501
Grand Canyon Tech
Grand Canyon Tech
