Roper REX3614KW Electric Dryer Logo
Posted on Aug 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer runs for 5 minutes then stops
The dryer runs, the tumbler works and the dryer heats up. It will run for about 5 minutes then it stops. If I push the "Start" button it will not stat again but if I wait for a while the "Start" button will start again and run for about 5 minutes. What is the issue??
  • 4 more comments
  • Anonymous Mar 18, 2014
    Dryer shuts off after a few minutes and is very hot, it will restart after it cools off and then run only for a few minutes again and be very hot.
  • Anonymous Mar 22, 2014
    the dryer starts and runs for 5 minutes properly but seems to stop for no reason after 5 minutes
  • Anonymous Mar 24, 2014
    dryer runs about 3 minutes, heats up and stops with e64
  • Anonymous Mar 27, 2014
    Runs and cuts out and runs after few minutes
  • Anonymous Mar 30, 2014
    dryer starts but the stops 5 or 10 minutes later but will start back if you push the start button
  • Anonymous Mar 31, 2014
    dryer will run for ten minutes but then stops and all the lights on the front panel blink. Also no heat
Anonymous
Level 3:
  • Master 625 Answers
  • Posted on Aug 21, 2007
Anonymous
Master
Level 3:
Answers
625
Questions
7
Helped
679705
Points
1177
Look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 • Dryers
18helpful
Breaker popped, so went and turned it back on. Now there is no heat. What could be the problem?
In your dryer behind the tumbler there are coils with insulators. up against the dryer wall their should be many holes that allow the heat to come into the tumbler. run your dryer about 3 minutes with settings on heat , then open the door and peer thru to the back while the tumbler is spinning. if you don't see part or full radiat heat. the heating coils will have to be replaced. you can purchase them from most appliance parts store. just make sure you provide the brand and model # and possibly the ser#. good luck!
Dec 30, 2010 • Dryers
GE Dryer works but keeps stopping after only 5 minutes
IT SOUNDS LIKE YOU NEED TO REPLACE TERMOSTATS.
Oct 19, 2009 • Dryers
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
5helpful
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
DRYER RUNS ABOUT 15 MINUTES, HEAT WORKS,MAKES NOISE AND STOPS
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
gdhi64
2helpful
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Dryer stops after 5 minutes
dryer moter is covered with lint and over heating.if the moter is not completely burned out `you mite clean it with air pressure .if it still does it `replace it.
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
