Go on hp site (www.hp.com) and find the lan driver. downloadd and install it.
use this link to get your lan card driver: http://welcome.hp.com/country/us/en/support.html?pageDisplay=support&jumpid=in_R329_prodexp%2Fhhoslp%2Fsplit%2Fsupport
Hi, To remove this error, you have to download and install the following HP COMPAQ D530 SFF Microcode Update Download the update from the above link. Read / follow the instructions carefully. This package contains a utility that can be used to install or upgrade
the processor microcode on the listed HP Compaq Business Desktop D530. Hope it helps! Good Luck! CreativeTECH
You can get a maximum of 4GB of ram. Yes you can also upgrade your drive, probably to a lot larger than 80.
The following is a link to the manual that you can download, in PDF format, that has information on upgrading/adding both memory and hard disks for the HP d530 SFF. It has both diagrams and instructions.
Here is a link that has drivers for this computer.These are all drivers that come installed on it from box. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=uk&prodNameId=316715&prodTypeId=12454&prodSeriesId=316713&swLang=13&taskId=135&swEnvOID=1093
your operating system should detect and install the drivers for your network controller if it is an internal on board LAN. however you must be sure that you have the LAN enabled in your BIOS setup under the advanced selection on the bios screen. otherwise , your operating system won't even see that you have a LAN connection.
Are you saying you are missing the drivers or the NIC card?
