I have instructions for adding a name to a Norstar set. I believe this will add the name of a person to an extension number. These instructions call for the use of a Norstar Overlay Template. I am assuming that this template renames the buttons on the right of the phone. I have followed the instructions to a point where it says press "Show". At this point the buttons "Call Fwd.", Speed Dial" and "Line 1" are all lit up. Obviously one of these buttons is the "Show" button.
Does anyone know what these buttons would be if they had a Norstar Overlay Template on them? The receptionist phone is a Norstar Meridian M7324 but all the office phones are the M7310.
Mac Higosoft Web Player is a web video creator and publishing tool for Mac users. With Higosoft Web Player, you are able to publish and display videos online, and then embed the generated flv player on any websites and personal blog.For detailed information about HigoSoft Web Player, please feel free to visit http://www.web-player.us
Higosoft Web Player is the newly published web video creator and publish tool for you to display flv video online in your own way, such as add ads like text, image,video or swf to redirect people to your websites, you can and embed the generated flv player on any websites and personal blog to promote your product or services. Below is the way to use HigoSoft webplayer Step 1: Add flv video Click “Add” button to import videos to this software You are also able to do some basic setting for the videos, such as specifying hyperlink for the videos when clicking on the videos or when the video playback comes to the end.
Step 2: Add advertisement In the "Advertise" tab, Higosoft Web Player provides you with two modes to insert ads on videos, including “Insert” mode and “Overlay” mode. It allows you to add different types of ads inside or over your videos, such as text ads, image ads, swf ads, and video ads In "Insert" mode, video will be paused to display the inserted object for a while depending on the duration set for the object, and after the duration, video will continue to play from where it's paused In "Overlay" mode, the added objects will flow on the video and be displayed with the videos in the same time.
Step 3: Choose skin and style Higosoft Web Player for Mac is equipped with abundant amazing web flv player skins and templates all of which are within "Template" tab. You can select whatever web flv player your like from various options provided under the "Style" sub-tab, get further control of the apperance of web flv player choosing from "Options" sub-tab, add watermark and logos for your published videos under "Addons" sub-tab and choose choose your favorite preloader when the video is buffering.under "Misc" sub-tab.
Step 4: Publish your videos to website It is maybe the final purpose for HigoSoft web player, with it you are able to publish and display amazing videos online in a well-designed and elegant flash video player. When you come to publish the videos online, you have two kinds of publish mode to choose. One is “Embed” mode and the other is “Out File” mode. The difference between these two modes is that under “Out File” mode, the software will generate additional xml file named “medialist.xml”. That is to say, when you publish in "Embed" mode, generally two files produced "dwplayer html" and "dwplayer swf" but with "Out File", the additonal "medialist.xml" file generated.
For more imformation about how to use HigoSoft web player, please visit http://www.web-player.us
There isnt an exact way to add a signature at the end of the txt. In order to do so, you have to create a template with your signature, then insert the template at the end of your txt. However, know that it will count towards the 160 character limit. Instruction from the user manual (pg 38-39) below. Hope it helps!
Message templates When you often use the same phrases, you can save the message under template messages. Adding the message as a template
Press Menu > Messaging > Templates.
Press Options > Add New.
Write the frequently used message > Options > Save.
Sending a message with template
Select the message to send.
Edit the message > Options > Send.
note: You can add a template while writing message. Write a message > Options > Add Template. Choose Text or Multimedia and select the message to add.
It is on of the keys on the side. The 8 keys from top to bottom are:
Copy/Yes
Backspace/No
Change/Remove
Add/Default
Heading/Retry
Show/<-- View -->
Back
Next/Ok
Excerpt from the 7208 Programming Overlay
-> You need a new extension number for your set? -> You need a new extension on your set so you can see when they are on their phone?
If it is the first, there are many things that you need first, too much to explain at the moment. But you need to have the password and a template for your phone to make changes.
If it is the second, press: - Feature * 0 and any button to find out what is on the button, look for an empty button or one that you want to overwrite, - then RLS, - press FEATURE * 2 - press the button where you want to add this new extension - dial the extension of the new person
As far as the name goes, I assume that it must be a watermark / overlay that is programmed into your printer driver. Go to the printer "properties" and go into "printing preferences" and select "custom settings", and check the watermark/ overlay settings. There are a couple of different drivers , so the location of this could vary slightly. As for programming Email? If you have some addresses programmed and working already? The easiest way to add more is to open a web browser and type your printer's ip address in the address bar, select "administrator Mode". The default user name is "admin". The default password is either "password", or just leave blank (can't remember which) select "address book", then you will see the names of the destination you have programmed. If you highlight one of them and select "change" you will be able to view the settings that need to be made. Then exit out of that page, and select "add" and input the information for the new destination. If you have not setr up scan to email, you will need to make many other settings in the web browser that I cannot go through, but it involves all of your TCP/IP settings, email settings such as user name, password, SMTP, POP, etc...etc. Hope this helps.
This is for an M7324. Place the programming overlay on the top 4 buttons of the phone. Press Feature **266344, Password: 266344 Terminals& Sets should be in the display. Looking at the overlay press Show, press Next until it shows the name or ext. that you want to change. Press the button under CHANGE in the display. Enter the new name (use the arrow over button to move to the next space). After you are done press Show and RLS. Update will appear in the display press the button to update the change.
