This phone is absolutely rubbish. You cannot turn off the deafening sound when you turn it on and off and it is not at all easy to use. The complete opposite of what it is promoted to be. I bought a Doro phone for my Dad - more expensive but really easy to use and very clear.This phone is absolutely rubbish. You cannot turn off the deafening sound when you turn it on and off and it is not at all easy to use. The complete opposite of what it is promoted to be. I bought a Doro phone for my Dad - more expensive but really easy to use and very clear.
Press Menu, then scroll down to Settings using the bottom bar on the SOS button, then User profiles, then General, then Customize then Tone Settings then Power ON then press Silent. Then do the same for Power off. If you have any problems ring the distributors at Winning Deals and they will talk you through it and any other queries. I think this phone is rubbish though especially as it's targeted as being so user friendly. The phone number is 0844 967 1145. disabled people.Press Menu, then scroll down to Settings using the bottom bar on the SOS button, then User profiles, then General, then Customize then Tone Settings then Power ON then press Silent. Then do the same for Power off. If you have any problems ring the distributors at Winning Deals and they will talk you through it and any other queries. I think this phone is rubbish though especially as it's targeted as being so user friendly. The phone number is 0844 967 1145. disabled people.
You can't post conmments that contain an email address.
That TV has a lot of audio adjustments on it. Try changing the equalizer settings in the mid range. You may also want to see what it does when you hook something else to it and check the sound. If all else fails you can try the digital audio connection to see if that is clear. Otherwise you may to replace the audio board.
I was told by on star that if you leave the drivers door open for 90 seconds and then lock all of the doors and wait until the next day the system will reset itself. I know this sounds like smoke and mirrors but it does work. Please let me know. Hope this helps.
hey!! due to high frequency sound... the speakers of ur phone has been damaged...... please get it repaired from any repair centre..... it may cost between 100-150 rs.
Then go to control panel,system ,hardware ,device manager option There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly please reinstall sound drivers properly
or else
In control panel , select sound audio devices open it there u have volume,sounds,audio,voice,hardware options
1)See whether it is mute 2)In audio option select default audio device and recording device should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Have the audio jack repaired it's not making contact on the connecting plates properly. You ould have a go at this if you are very good with fine electronics
I have worked out how to do it now. Take the following steps:
