Can anyone tell me if its possible to wall mount my Sanyo LCD-32xr8DA tv? There don't seem to be any holes at the back to attach brackets.The tv is 2009 model so may be too old and not designed to be wall mounted?? I have a universal wall bracket to put on it just can't figure out how! Any help would be greatly appreciated.
Look at the middle of the tv the 4 screw mount thats wre the tv wall mount gos. good luck
Thanks for that. I'd initially thought that as well but the holes only fit tiny little screws in them ( holes are pre formed metal) I'm afraid if I use screws to fit it won't be strong enough to hold the tv.
The 4 pre formed metal holes are screw mounts for Mounting bracket and hardware it will hold the tvhere is images of a back of a sanyo lcd tv I hop this help good luck. .
SOURCE: Wall Mounting
I purchased my tv mount from Ultimate Electronics/ Las Vegas, NV. The name of company is Omni Mount, model: U2 Fixed. The phone number is 1-800-MOUNT IT. Good Luck.
SOURCE: 42'' LCD PLTV-4250 MOUNTING
The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
I have not seen any mounts that use more than four.
SOURCE: Attaching to wall mount
I want to remove my akai flat panel tv FROM the wall mount. The mount itself is attached to the wall by screws but it seems the tv had some type of nobs on the back that slid into slots on the mount. i cannot remember exactly how it was mounted 5 yrs ago. But the tv picture has blown and i need to remove it from the wall mount. I have tried lifting it to remove knobs on back of tv from slots but its seems locked. Can anyone help me with this problem.
SOURCE: Wall mount Akai LCT 3285TA flat panel TV
You have to get correct wall mount for this model tv.
SOURCE: Attaching Wall Mount Support to AKAI Flat Panel
You use the four outer holes as suggested in the manual on page 12, see below:
