Question about Lands Phones
T7208 continually says "message for you" can't seem to clear
Have tried unplugging
  • 1 more comment
  • abl14221 Mar 24, 2009
    it identifies another phone station.Tried ringing that extension.Messsage does not clear.Still says message for you.appreciate advice!!!! Thanks
  • abl14221 Mar 25, 2009
    EXCELLENT you were correct.Finally cleared! Thanks alot
  • Justin333 Apr 08, 2009
    I have the same problem when feature 65 is entered it prompts "Hold or release". What does this correspond to?
    Thanks!
Thank you, Feature # 65 worked for me on a nortel T7208
Posted on Apr 24, 2009
Fix is Feature#65 for me.
Posted on Apr 08, 2009
    President:
  • 860 Answers
The message was probably left manually by a co-worker and not the voice mail try entering feature 65 that should send you to who turned on the message light.when the station is called back the light should go out.
Posted on Mar 24, 2009
  • george  peters
    george peters Mar 24, 2009
    That should of worked . Whats it doing when you press feature 65?
  • george  peters
    george peters Mar 25, 2009
    its a guess that that station left multiple messages.
SOURCE:
I have a Nortel T7208 phone. It shows "Message fo...
I have a Nortel T7208 phone. It shows "message for you" and the light is on but when I open my vm. I don not have a message how do I get rid of this?
May 19, 2010 | Lands Phones
T7208 Nortel Norstar phone system - how to retrieve a deleted voicemail?
unfortunately when a message is deleted... it is deleted unless you have a back up
Mar 25, 2010 | NorStar T7208 Corded Phone
How do I listen to by mesasges on a Nortel T7208
To access your voice mail messages either press your open voice mail key (if programmed) or enter feature 981.
Dec 11, 2009 | NorStar T7208 Corded Phone
Trying to switch the extension number.
On the newer norstar systems the T7208 and lower phones can not be used for programming.The T7316e phone has to be used for programming therefore feature 983 will only work on the T7316e set.To change local dn's you have to go into config programming and to change dn old dn then new dn.
Sep 29, 2009 | NorStar T7208 Corded Phone
Message waiting indicator light is on but there are no messages
There is this thing on Norstar systems called Reply message... this turns on your voicemail light, but there is on messages when you go into the mailbox.
Try this: FEATURE # 6 5
There might be something on you set that will tell you who sent the message, and you can hit the # or press the OK button to cancel this message!
Good Luck.
Aug 20, 2009 | Nortel Business Series Terminal T7208 -...
The message light is continually on my T7208 - but no messages
That is FEATURE # 6 5 that you tried right? The screen will say "No Messages" once cleared.
Jun 10, 2009 | NorStar T7208 Corded Phone
Norstar meridian displays "message for you"
If you have no messages in your mailbox then someone has accidentally sent you a message from their phone set. You can usaully clear this by using the options in the display to delete all messages or try these feature codes
The Feature button is the gray button that looks like it has a globe on it located under the display.
Press Feature #65
or Feature #1
Mar 12, 2009 | NorStar BCM-T7208 Corded Phone
Lands Phones Logo
4,554 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
