Question about Dell Inspiron 1521 Notebook
Inspiron 1521 won't boot up. Get read disk error.
Computer was working fine, then starting hanging up. Turned it off and went to turn it back on, and all I get is Disk Read Error, press Ctrl alt del. Keeps doing the same thing. Ran diagnostics and get error 2000-0146. Any ideas?
  • Dell Master
  • 1,183 Answers
HI,
You can try the following steps
1. Check and remove all cds from the optical drive
2. Disconnect the Ac adapter and remove battery from the system
3. Hold and press the power button for 10 seconds
4. Reconnect ony the ac adapter and power on the system
5. check
Note the error message means following
PSA 1000-0146
PSA+ 2000-0146
DST Log contains previous error(s).
Generally the error is caused by the conflict with the optical drive
Thanks
Proton
Posted on Mar 23, 2009
  • 790 Answers
Hello!!
put ur OS cd and enter repair console and try fixboot command!!!
6ya staff
SOURCE:
NTLDR is missing press CTRL ALT DEL to restart.. How to fix wothout windows xp install or program disk
Try pressing F8 just before it tries to boot, you may be able to get into your system and back up your data. Then check out flea bay for a copy of XP.
Apr 09, 2014 | Dell Computers & Internet
Hello, While trying to boot up, I received the message, "disk read error occurred. Press ctrl+alt+del". The same message appears after I press ctrl+alt+del. What can I do to resolve the issue? Thank...
This is called a disk error which generally means your disk has failed. You need to get your data off it if it is not backed up. You will have to replace the disk.
A local computer shop might, just might, be able to install it into a second computer and read the data. The more you fuss with it the lower your chances of getting any data off it.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 16, 2010 | Dell Dimension 4500 PC Desktop
Ctrl+Alt+Del to restart error
Is it a black screen right when you boot your computer? If so this could be a fatal disk error and the harddrive has crashed.
There is no easy fix other than to replace the harddrive.
Oct 05, 2009 | Compaq Presario 700 470024-192 Notebook
Disk read error alt+ctrl del restart
load optimal or fail save setting then check if it eliminates the problem if it didn't work. reinstall the ide cable of your hard disk check if it eliminates the problem if it also didn't work back up your hard drive for important file, delete and create hard disk file system, partition and reformat your hard drive if this also didnt work replace your hard disk.
Sep 14, 2009 | Microsoft Windows® XP Professional Full...
TOSHIBA A135-S2386- I HAVE AN ERROR WHEN TURNING ON MY LAPTOP
your hd has bad sectors you need to repair it.
the clicking sounds is hd try to pass bad sectors like a scratched cd jumping.
send ur email and I'll send you software to repair disk.(hd disk)
Jan 30, 2009 | Computers & Internet
A disk read error occurred. the comp. said press ctrl+alt+del
The computer cannot find the operating system, the disk error message means it cannot find the hard disk, you most likely have a faulty hard disk or less likely a faulty disk controller.
You can test the hard disk by removing it and connecting it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer cannot detect this drive as an external drive then you will know your hard drive is faulty ad you need to buy a new one and install Windows and programs etc..
Jan 25, 2009 | Dell Latitude C400 Notebook
Restart Error: "A disk read error occured Press Ctrl+Alt+Del to restart"
Turn the pwr off for 5 minutes
turn the pwr on and tap the F8 or press the F8, 8 times
and select safe mode and do a system restore
Jun 01, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Dell Inspiron 1521 Notebook Logo
595 people viewed this question
Ekse
Clive
Clive
Alun Cox
