Question about Pramac Storm 5000 Watt Generator
How to change oil and what kind to use on a es 5000 generator
It has a 9.0 honda motor
  • 76 Answers
You should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Posted on Jun 29, 2009
SOURCE:
We have a Maxa ER 5000 Tecumseh Generator, changed the oil and spark plug, no fire. How do you check the low oil switch?
Nancy, If you think this is the problem, simply unplug it. See links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Disconnect Your Low Oil Sensor
Re Testing Low Oil Sensor on Honda GX Engine
How to Test the Low Oil Pressure Switch on Generator
Generator runs then shuts off
Feb 26, 2016 | Electrical Supplies
2005 Honda CG 125 Titan ES where is the oil filter
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2005 Honda CG 125 Titan ES where is the oil filter Google Search
how to do oil change on honda cg125
manual motor honda cg titan 125 pdf Honda Motor Vehicle Manufacturers
http://www.partsfish.com/page/oem-parts-for-honda
https://vk.com/doc-58384605_259152219?dl=2563ac90202e0691a8
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 07, 2013 | 2005 Honda CG 125 Titan ES
Honda 5000 generator with remote starter running rough.. tis like ******* or something.. oil was almost empty so i stopped generator and added oil and restarted.. can u give some advice as to how to remedy...
Those generators are set up with a low oil saftey but your gonna want to check compression anyways just to verify it is where it needs to be. Im gonna guess its to be between 120-160 psi, check your manual for the service limits. after that check your air filter, valve lash, fuel filter etc etc.
Mar 29, 2012 | Honda Mmd 5000 Watt Electric Start...
It starts with the switch fine but when i let go of the key it cuts off
Check for faulty low oil sending unit or oil level low or dirty oil (some generators have a fuel cut-out solenoid at the carb ). Key switch will override the low oil safety. Easy test, remove wire from oil sending unit. If unit runs, and oil has not been changed in a while, service engine and retest.
Sep 09, 2011 | Mi T M MiTM Generator 9hp Honda 5000 Watt...
Honda 5000 generator clear oil out leaking thru air intake
There is supposed some oil in there. There is a tube to the carb intake that allows flow like a pcv valve
Oct 05, 2010 | Honda Mmd 5000 Watt Electric Start...
Need service manual for a Honda ES4500 generator
Where do you change the oil on a Honda ES 4500 Generator?
Dec 26, 2009 | Honda Electrical Supplies
5000 watt generator no juice
most generators have a reset button. check your manual under the trouble shooter section good luck.
Jan 26, 2009 | Coleman Powermate Premium Plus 6250W...
Oil change
There are two 14mm bolts on both sides (lower) of the motor. Unscrew one or both and drain the oil....Replace with sae 30 or 10w30 oil and should take almost a quart. (Put the bolts back in and tork slightly.) Check oil level.
Jan 11, 2009 | Pramac Storm 5000 Watt Generator
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Pramac Storm 5000 Watt Generator Logo
545 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
wadingriver
wadingriver
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
