I have a problem in my camera- model Canon PC 1474. It is showing an error message mentioned below: Lens Error Will shut down automatically Restart camera Though I have charged the battery and restarted the camera n no. of times. this problem is not resolved.
SOURCE: Lens Error - Restart Camera : Lens remains in extended position.
Hey,
I had the same problem as everyone else regarding the error that would pop up stating that there was a lens error. I had the camera in my pocket when I went to a hockey game, pulled it out to take a picture, and it didn't work. Needless to say I was pissed because I expected far more from Canon. I was just about to go and buy a new camera, and figured that I would try to troubleshoot the problem and stumbled upon this site. Someone suggested turning the camera on and off while twisting the lens, so I figured it couldn't hurt to try it.
Before trying this, my lens would not retract all the way, the cover would not shut, the image was blurry, and I could not zoom in at all or the camera would show the error.
So, I tried the "twisting" solution, and it wasn't working, but I think I was being too delicate with it. I put a little more pressure on it and gave it a good twist. There was a clicking noise as others have said, but in the end, it worked after about 2 or 3 minutes of messing with it. No my lens goes down, the cover shuts and its clear as a bell. Not sure if this is a recurring problem as it appears to be a common problem, I fully suggest trying this before you send it off to get it fixed for a ridiculous amount of money.
Best of luck
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
SOURCE: canon sx200 is, lens error restart camera
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
SOURCE: Canon Ixus 130 gives message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
