Canon imageRUNNER 2200 Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon IR 2200 error code E000002-0000
Display says to cycle main power switch...no go. Any help would be great! thanks
millstones
Level 2:
  • Expert 59 Answers
  • Posted on Mar 23, 2009
millstones
Expert
Level 2:
Answers
59
Questions
Helped
105798
Points
171
It's to do with the fixing unit (hot bit) left hand side. Make sure theres no paper **** any where near it. If so switch off then on.
If not it looks like there may be a fault with the fixing film or may just need the error resetting in service mode.
Canon Photocopier ImageRUNNER 7200. Error E000677-5802 appear in it.
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
How can i resolve the error code of E002-0000 on IR 2202? when i switch on it mark that error and refuse to operate please help us
I believe that model number is wrong......You must be referring to a Canon IR 2200 or maybe a Canon IR 2220. The Fuser has a problem when warming up. Replace the fuser or the Fixing film assembly and then the error must be reset in service mode.
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
3answers
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
53helpful
6answers
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
3helpful
3answers
Error
E000007-0000 code is Fixing Film error.
FM2-3346-000
1 FIXING FILM ASSEMBLY 120V
FM2-3353-000
1 FIXING FILM ASSEMBLY 230V EXCEPT CN
FM2-3329-000
1 FIXING FILM ASSEMBLY 230V CN
6helpful
2answers
IR2200
When I pluge my Canon IR 3300 is showing me to Turn OFF and ON the Switch in the right, if the problem did not solve, so please send solution on Email - [email protected]
14helpful
3answers
E000014-0000
E000014-0000 ir 3300 canon machine solution
old marine
old marine
ZJ Limited
ZJ Limited
