SOURCE: please give me the master code for my phone. nokia
Get the Master Reset Code for the Nokia 1110 Model Mobile at http://www.mobile-unlocker.com/nokia-dct-master-code-service/rs2wp10/
SOURCE: Don't worry there is Solution
Hello, note that,12345 is the factory master code for nokia.
If fails, get the code at www.nfader.su
If still fail , get it unlocked at www.unlock-zone.com
Regards, J
SOURCE: i forgot my nokia 1209 RH-105 security code. IMEI
dont worry, just follow the steps below:
note: u need to have a pc running xp
click to download NSS
http://www.b-phreaks.co.uk/NSSDownloadLanding.htm
TO RECOVER THE CODE
1. CONNECT UR FONE VIA USBCABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
2. THEN INSTALL Nemesis Service Suite
3. SELECT USB VIRTUAL DRIVE during installation (in case of nokia6120c for nokia 5700 use diamond protection)
4. AFTER INSTALLATION OPEN IT, THEN CLicK ON SCAN BUTTON
5. AFTER THAT CLicK ON PHONE INFO, NOW CLicK ON SCAN
6. NOW CLicK ON PERMANENT MEMORY TAB given on right bottom of application
7. NOW CLicK ON READ, IT WILL READ THE PERMANENT MEMORY FILE & WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:Program FilesNSSBackuppm?252*********.pm
open that PM file in NOTEPAD
8. now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31303038350000000000 remove all the "3" digits and it will be like that
5= 10085 0000000000 now its 10085 thats it.UR LOCK CODE IS 10085
SOURCE: unlock my nokia 1209 mobile imei no-359335/03/202551/9
Its possible by codes.Get the unlocking code from prounlocking.com
Once you get the code, you may follow the instructions at http://www.mobileunlockguide.com/ .It helps to unlock your mobile easily.
