Windows media player is not playing that shows informatinWindows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly.
First of all, you can try to repair this problem with solution offered in this article about How to Solve Windows Media Player No Picture Just Sound, if it doesn't work, you can try to update the player.This is the easiest way for you to solve the issue. If you don't know how to update Windows media player, you can check the following guide.
Guide: How to Update Windows Media Player?
Three situations to fix Windows Media Player not playing audio, including volume settings adjustments, the update or reinstallation of the software, installation of codecs.
You can check on this article : "Windows Media Player Play No Sound" You can follow the next detailed instructions to correct my Windows Media Player won't play sound issue.
Try updating the version of windows media player to the latest, 7 i think.
Are the problems with Media Player only? Are you getting the normal system sounds? Does any other media player work such as RealPlayer or Quicktime?
Have you attempted to update the drivers of the sound-card? Have you attempted to uninstall then reinstall Windows Media Player?
