Question about Acer Aspire M5100 AM5100-U5313A AMD Desktop PC - AMD Phenom X4 9500 Quad Core Processor 2.2GHz, 3GB
Hi, I'm thinking of upgrade my CPU, but I don't know which CPU:s my system can support and also if I need to upgrade my BIOS to what version for this? Do I need to change any jumper settings on the mother board? Where can I find a motherboard manual? I have the following, pls. see below. Best Regards, Tore SiSoftware Sandra reports: Processor Model : AMD Athlon(tm) 64 X2 Dual Core Processor 5600+ Speed : 2.79GHz System System : Acer Aspire M5100 Platform Compliance : AMD LIVE! Mainboard : Acer F690GVM Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Phoenix Technologies, LTD 6.00 PG Total Memory : 3.25GB DIMM DDR2 Version : R01-A3 MPS Version : 1.40 Model : F690GVM Type : Mainboard System BIOS : 10/10/2007-RS690-SB600-6A669FK8C-00 Chipset Model : Foxconn RS690 Host Bridge Front Side Bus Speed : 1x 200MHz (200MHz) Chipset Model : AMD Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1GHz (2GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 399MHz (798MHz) O/S: Vista Home Premium.
  • 118 Answers
Check compatabilty check online for your board chipset on the www.acer.com/support will find the solution for the upgrade cpu compatabilty, gudday !!
Posted on Mar 23, 2009
SOURCE:
Compatibility of Athlon CPU and ASUS Motherboard
Yes it will work just fine. Just download and update your Bios to the latest version which is the 1007 release and you should be good to go. You can get the latest Bios here:
http://dlcdnet.asus.com/pub/ASUS/mb/socka/sis741GX/A7S8XMX07.zip
Jul 12, 2012 | Computers & Internet
Toshiba Satellite a65-s126 CPU change
i think you have not placed the coolant paste properly.
or you have not removed the cover over that paste
Oct 07, 2008 | Toshiba Satellite A65-S126 Notebook
Can the cpu be upgraded to BX80526C1000256! If yes what modifications need to be made? Motherboard is EliteGroup P6STP-FL
Hello!
If you want upgrade you CPU, you must first know, specification of motherboard.
If the motherboard can´t see a new CPU, more exactly bios, you can try only one upgrade bios.
I give you a link for a manual and upgrade bios.
When you upgrade bios, try new CPU, if bios again don´t see a CPU, you can´t do anything about that.
Nov 03, 2009 | EliteGroup P6STP-FL Motherboard
Cpu overheats
the alternative but not the best solution is to buy one of those usb powered laptop chillers
Robert
Jan 27, 2009 | Acer Aspire 7720 Notebook
P5NT won't boot
I went throught this and it is really silly. The P5N-T motherboard has a problem with some of the new energy efficient CPUs. The fix was to insert an older CPU and upgrade the bios and then it would recognize the new CPU. If you happen not to have an older 775 CPU laying around (most people do not), it might be easiest to return it and get a different board - or maybe the store can upgrade the bios for you.
Oct 05, 2008 | Computers & Internet
Upgrading my laptop's processor from celeron 540 to 560
Fan cooler for Celeron is usually the same for 540 and 560 Ghz, there should be no need to replace cooling system if you pass from 540 and 560
Whenever you operates on CPU and cooling system you need to monitor CPU temperature using Bios or a dedicated software. Here is a good software to check CPU temperature and Fan activity: SpeedFan Download.
Regarding the RAM, some seller like this one (UK seller).sells Trascends 2 GB modules, seller says they work on 4315, you can eventually ask them if there is any issue with bios version and if you need to upgrade bios.
Remember, CPU upgrade on a laptop is not a simple operation, be careful if you do it yourself, as it is easy to damage the laptop when taking it apart. Regarding RAM, main risk is incompatibility, If you live in UK the seller above guarantee compatibility with Acer 4315, double check by sending them an email before buying.
Aug 11, 2008 | Acer Aspire 5100 Notebook
Intel cpu ucode loading eroor
You can upgrade your bios, you just need to visit the motherboard manufacturer site where you can download the latest bios.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=1276&modelmenu=1
You can also try to reset the bios first, you can reset it to default settings and if that will not work then you can upgrade the bios.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
and you can also check this site regarding bios upgrade
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Mar 21, 2008 | ASUS P5PE-VM Motherboard
BIOS DISPLAYING INCORRECT CPU SPEED
Hi, I have to agree "...that the motherboard's bios doesn't recognize the processor and that I should upgrade the bios...". Though I think that this is only a display issue and not necessarily true CPU speed. You can check if the correct CPU is displayed inside Windows by right click on My Computer and details would be shown in the System Properties. To upgrade the BIOS: 1. Determine/log your current BIOS and its date by pressing Pause on initial boot when motherboard details are shown; 2. Continue booting by pressing escape and run your Windows normally. Go to the website of your motherboard manufacturer and verify if they have an updated BIOS (compare date of release). If an updated BIOS is available, download. Likewise download the flashing utility. Further instructions are also available on a step by step procedure. Some newer mb versions/models have a Window based update feature. Check if you have such. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 28, 2007 | Soltek SL-75FRV Motherboard
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
Acer Aspire M5100 AM5100-U5313A AMD Desktop PC - AMD Phenom X4 9500 Quad Core Processor 2.2GHz, 3GB Logo
1,199 people viewed this question
Ekse
Alun Cox
