Epic View 550 Treadmill Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Incline wont work
I have a 3 series reebok treadmill and tryed to fold it last night but forgot inlcine was still up so it was then stuck as the highest point managed to manually reduce incline but now it wont do anything you can change the level on the computer but it doesnt do anything
Anonymous
Level 3:
President:
  • Master 1,734 Answers
  • Posted on Jul 06, 2009
Anonymous
Master
Level 3:
President:
Answers
1734
Questions
Helped
1110065
Points
3296
Check here for the user manual:
http://manualfox.com/link/reebok.htm
And maybe send them a manual request?
Reebok 8000ES stuck incline position will not decline.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj79pDHxZSCAxV_AHkGHbhiDxkQFnoECBsQAQ&url=https%3A%2F%2Fwww.justanswer.com%2Ffitness-equipment%2Fgdah0-reebok-8000es-treadmill-incline-keeps-going.html&usg=AOvVaw0mEH-BLg44uwLpy6jJGb3K&opi=89978449
My Reebok 9500 ES Treadmill is stuck at it's max incline.
  1. Check the belt: Make sure the belt is properly aligned and tensioned, as a misaligned or loose belt could cause the incline to get stuck.
  2. Check the incline motor: If the incline motor is not functioning properly, it could be preventing the incline from moving. You may need to have the motor inspected or replaced.
  3. Check the incline sensors: If the incline sensors are not functioning properly, they could be preventing the incline from moving. You may need to have the sensors inspected or replaced.
  4. Check the control board: If the control board is not functioning properly, it could be preventing the incline from moving. You may need to have the control board inspected or replaced.
If these steps do no
My Reebok Jet 200 is stuck at an incline
If your Reebok Jet 200 treadmill is stuck at an incline and you are unable to lower the incline to the 0 position, there are a few things you can try to fix the problem:
  1. Check the incline motor and make sure that it is properly installed and functioning. If the motor is damaged or not functioning properly, it may be causing the incline to remain stuck.
  2. Check the incline control board and make sure that it is properly connected to the incline motor and other treadmill components. If the control board is damaged or not functioning properly, it may be causing the incline to remain stuck.
  3. Check the incline cable and make sure that it is not frayed or damaged. If the cable is damaged, it may be causing the incline to remain stuck.
  4. Check the treadmill's belt and make sure that it is properly aligned and tightened. If the belt is misaligned or loose, it may be causing the incline to remain stuck.
  5. Check the treadmill's power supply and make sure that it is properly connected and functioning. If the power supply is not functioning properly, it may be causing the incline to remain stuck.
If you have tried all of these steps and are still having issues with the incline on your Reebok Jet 200 treadmill remaining stuck, you may want to consult a professional for further assistance. A treadmill repair technician will be able to diagnose the problem and recommend the best course of action to fix it.
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
My rt 1000 wont fully decline and then will not fold away
If this a Reebok unit their is a sheet under the motor shroud and will give the calibration procedure for this. If this does not work then you may need to unplug unit and mechanically unfreeze the incline motor. Call Icon Fitness @ 1-800-999-3756 they may help you thru this or refer you to one of their authorize servicers.
The belt won't move and the incline is stuck. display isn't working properly either
reebok 8000es incline keeps going up and down and will not stop or go into any other mode
2helpful
2answers
Treadmill wont incline all the way
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds reinsert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. Thi will recalibrate the incline system.
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
