Is this product on recall? If not then it should be, I bought this tablet for my son and from day one it wouldn't turn on, my husband suggested that we let it charge over night. The next day it turned on for only 15 mins.
Have you tried taking the battery out? That solves a lot of problems.
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
SOURCE: my coby kyros internet tablet wont turn on
i cannot turn on my coby kyros internet tablet after charging and there are no answers or problem tips in user manual
SOURCE: will not take charge
Sounds like your battery is knackered, only thing to do is replace it, you can check the battery with a voltage meter or take it back to the supplier and ask them to check it foryou.
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
