I have recently bought the Pioneer VSX 1018 AH-S av receiver and have connected Mordaunt Short MS 908i floorstanding speakers and MS905i
center speaker which earlier were giving excellent sound quality connected to a Marantz SR4600 recevier.
The Pioneer gives a very high sibilant output in both stereo as well as movie playback ! I have tried to reduce treble to minimum level but still
find the "S" sound as very sibilant and harsh !
Please let me know how to resolve this problem
Amit Gupta
Suspect a DTS board capacitor failures the ESR characteristics.
To troubleshoot connected any available device to RCA stereo connections at input to multi channel in. Test input to the corresponding speaker output confirming audio quality. This circuit bi-passes the DTS function and connects to the power amplifier for the speaker.
Connect any audio amplifier from the preamp out and confirm the quality of the audio.
I suspect that the pre-amp out will contain the distortedf noise. If the distrotion appears in all the channels it is most likely the DTS.
These are repairable.
Hope this helps?
SOURCE: Dear Sirs, I have
Did you remember to remove the shorting link on the MA BR5 speaker terminal ..When you biwire the speakers you should remember to loosen the speaker terminal nuts and remove the shorting link plate between the HF and the LF terminals or you will short the amplifiers two channels together through the link. And modern amplifiers will take a lot of abuse at low volumes but at high volumes the protection circuit will turn off the device.
