what country? this is the WWW, post country for better answers.......!
Only a scope can see the fast 5mS signals to the coil.
so its either the coil pack or the ECU blown. (wires are always suspect)
you never said , all 4 are dead, or 1 or 2, and how many packs.
some non usa cars have wasted (2pak) spark , not 4 COPS.
state what cylinders have spark and which don't.
there are only 2 ways to fix cars.
1: guess and swap parts
2: use tools. my guess is you dont have them.
some coil packs are active (ignitor inside) others just a coil.
you can test the restance of the coils, with a DMM , ohm meter.
if active you cant.
the fsm covers this on all cars.
https://suzukipitstopplus.com/category/3-suzuki-service-manuals.aspxthe 2006 Forenza as delivered to USA has.....
has a large single, dual wasted spark coil pack. (brick)
it does in fact have , internal ignitor drivers. inside. so can not be tested
with and ohm meter on the primary side. but can be on the secondary
you do know how to test wasted spark , right, All spark plugs must be
attached and grounded for the coil to work,
1and 4 are shared.
2 and 3 are shared.
so to test , you must keep the spark plugs (both or all 4 is best)
attached and the shells of spark plugs grounded.
there is a fuse that powers the coil pack. (usa)
the fuel pump relay sends power to the coil pack.
so of that is dead,so will be the pack. (im reading FSM as it type)
get an FSM.
pin 2 on coil pack is power. 12v.
pin 1,is spark 1&4 drive (fast ECU pulse)
pin 3 is 2&3 coil drive. (scope can see it)
recap, are you using the correct wasted spark testing method.
and are all 4 spark plugs dead.?
have you checked the relays under the bonnet could be marked engine cont or similar ??
