Teac Hi-Fi Radio w/ iPod Dock BLACK (TEAC-SR-L200I-B) Docking Station Logo
Posted on Mar 23, 2009
I cannot set the clock on my Teac MC-DX50i
How does one do that? I don't have a manual.
  • sderene Apr 10, 2009
    I cannot set my clock - please help.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2396
Points
17
I've found that I can only set the clock using the remote. Press and hold the 'time set' button on the remote, and using the forward and back buttons on either side of the play button, you can change your clock to a 12 hr or 24 hr time setting. Once that is set, press the 'time set' button and that will switch you to the hour, and using the same forward and back buttons, set that. Repeat the process to set the minutes. Press the 'time set' button again to exit out of if, and you're all set!
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 02, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3128
Points
15
I have found that you have to turn the system off or put it in standby mode. Then push the Time Set button and use the forward and reverse buttons to change the time.
1 Related Answer
Anonymous
SOURCE: I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
TEAC MC Dx50i my CD will not eject! It try but just clicks........help please
Common issue and it due to a broken part in the tray loading mechanism. The best route based on price is to replace the CD player.
1helpful
My teac mc-dx50i subwoffer wont turn on and its even plugged in
About all you can do is to make sure it has power and input from the main system. Past that, the amplifier in the subwoofer is most likely damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
4helpful
2answers
TEAC MC-D78 stopped reading discs,everything else is ok.
sir try to clean the lens in disc mechanism maybe the lens got dirt.. try to visit this link to access operating manual for your player.. its free to register.... tnx..
http://www.nodevice.com/manual/newmans/teac/MC-D78pdf/get50635.html
if you think i help you plzz rate me tnxx... goodluck
I have a Teac Mc-dx50i Shelf System and it won't turn on. I was moving it from one room(playing fine) to another. Set it up, plugged it into the wall socket, turned it on and it will not power up. The...
First checked the outlet if it is live by plugging another unit to confirm if there was voltage coming that outlet. Let me know if it has a power.
Jdvillanueva
3helpful
How do you set the clock
This is on page 23 of the manual for your device... This is the web link...
http://www.teac.com/resources/pdf/mc-dx32i/MCDX32_B_OM.pdf
If the unit is on, press the STANDBY/ON switch to turn it standby
2 Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. "12" or "24" blinks. If you want to change the hour mode, press the .or/ button.
< If you leave the unit idle for 7 seconds, the time setting mode will be cancelled.
3 Press the TIME SET button once more. The "hour" value blinks.
4 Press the SKIP button (.//) to set the current hour.
5 Press the TIME SET button. The "minute" value blinks.
6 Press the SKIP button (.//) to set the current minute.
7 Press the TIME SET button. The clock starts.
Teac mc-d90 need a manual for this item
http://www.user-manuals.com/advanced_search_result.php?keywords=mc-d90+manual+pdf&amp;forward=plist
At the link above they sell the manual for 10$ you can also email teac to inquire about their cost for a replacement. [email protected]
Thank you,
Lee
1helpful
The remote(RC-1185) for my DX 50i has never worked
www.remotes.com Remote model # RC-1185 $53.95
4helpful
2answers
Re: setting clock and stations
Is there a reset button on it
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
