This is a two year old 10 cu. ft. Avanti top freezer bottom refrigerator. Freezer compartment works, but frig compartment does not get cold. Freezer fan blows cold air into frig compartment only when freezer door is open. Cold air stops flowing down once the freezer door closes, not even worm air blows down. Opened freezer back panel and coils is all frosted with ice build up. I don't se a defrost element in the freezer compartment.
It looks like if I can get the cold air to blow down into frig it should fix the problem. Is there any air ducts that may be clogged up with ice?
Any help in troubleshooting is greatly appreciated.
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
exact same problem, help anyoe
