Filter lights on your Air Purifier
http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm
One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
When most people think of Oreck, an air purifier is usually not the first thing
IQAir Dental Series Air Purifier
UV air purifiers are very effective at neutralizing airborne pathogens
HEPA Air Purifiers
REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
Ozone Air Purification
Ionic air purifiers come in three different forms
WHOLE HOUSE HEPA
Dehumidifiers - Ebac Orion
Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
I have tried multiple power sources, and confirmed the outlets I am using work by plugging other things into the same socket. Replacing the fuse involves a soldering iron. But I did test it with an ohmmeter and it reports zero ohms across the fuse, and visual inspection seems to indicate it's OK. Keep in mind that both units are not working, and they are in different rooms.
On both units at the same time? It is not the case. I contacted Hunter and they are replacing both units as they should not have failed. Their return policy is very generous.
