This only shows on the operator extension. It is there to notify you that a Night or Evening or some other service is turned on. You can press the LIST soft key to find out which service is in effect. You can cancel the service, but then you also cancel the purpose of the service like night ringing or directing some lines straight to voice mail. Feature #871 will cancel ringing service, #872 will cancel restrictions service, and #873 will cancel routing services.
SOURCE: Message waiting but no message on display
What extension? If this is set as the receptionist, the general mailbox may be lighting the lite....check the general mailbox.
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
