Question about Sylvania DV220SL8 DVD Player/VCR
I lost the manual to Sylvania VCR/DVD player.
I know how to play back, but don't know how to record. I hit the menu and setting clock came up. No matter what number I hit nothing showed on the screen, so I couldn't set it.
  • Anonymous Apr 30, 2009
    I can't program my vcr either.
  • 20 Answers
Go to this site, find your remote and read the instructions:
http://www.xdiv.com/remotes/
Posted on Mar 23, 2009
SOURCE:
How do I change EP,SP,and other?
As you may know, the EP,SP issue is related with VCR function (Recording ) only..
it is selectable only before recording session starts..while it plays any VHS cassette whatever the speed is , it selects automatically..there should be either a small switch in control panel or in the recording speed in "SET UP MENU "
let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sylvania SSD803 DVD Player/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
CAN VIEW THE DVD ON A COMPUTER OR THE DVD RECORDER BUT NOT ON DVDS PLAYERS BOUGHT BEEFORE THE RECORDER
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
User manual how to set clock on Sansui dual dvd vcr player.
Go into SYSTEM SETUP. thats where the clock settings are.
Mar 12, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Can,t Record from VCR to DVD
Make sure you have your VCR connected to the recorder by either the ANTENNA cable or 3 A/V cords. Make sure the recorder is on whatever output channel the VCR is set on (switch on the back of the VCR) for RF, or that the VCR is set for AV output and the recorder is set for Input 1 for the back of the recorder. You should be able to see a picture on the recorder of what's playing on the VCR. If you got that far, then you should be able to record the incoming program using the menu features of the RCA 8030. I hope this helps.
I need a manual for this machine if anyone has one.
Feb 20, 2009 | RCA DRC8030N
I cannot program the vcr to record i just do not know how to I can play tapes or wath the disk but cannot recore
make sure the tv is on channel 3, and the vcr also on channel 3 -if trying to record from cable or satalite. then make sure tape is rewound all the way. do a test by hitting record on vcr. let it record for a few minutes. rewind it, then just hit play. Dont change any channels until you are ready to record the program of choice. After this test. And recording is successful. Rewind the tape again. And change the channel to your choice. Hit record at time of or go into menu of your vcr and set up a time to record shows.
Jan 04, 2009 | Symphonic WV806 DVD Player/VCR
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Channel stuck and can't record shows the same night
Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
-Tha Mp3 Doctor
Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
Sylvania SRD4900 DVD/VCR combo problem
Hi I am Temperance MI and I see this mode in my shop often, does any onscreen menu come up when using the remote and
going into menu? If not maybe the remote is bad, common just
a loose battery lead, If you are able to go into menu, and set the
clock, but unable to set timer record, look closely at you recordable tape to make sure on the left bottom from corner the
the recording tab is in place, You can place scotch tape over this hole of existing tab to ensure it will go into record. Finally
if it wont go into record when you try to use OTR, you
make a problem with the record ready switch in the VCR section. Joe . East Electronics, Temperance MI
Jan 23, 2008 | Durabrand DUR7 Portable DVD Player
Record
i have uploaded the user manual for this model, it should be visible within the next 24 hours. the quick version is this:
if you haven't done so yet, set the clock
menu/ use up/down arrows to select "clock set", press right arrow to select, set day, year, etc using up and down arrows, when each is set, the right arrow moves you to the next bit
once clock is set
timer recording
menu
use up and down arrows to scroll to timer recording, and press the right arrow to select
set the program number (1-8)
set frequency (once, daily, weekly)
set the date to record
set start time (i usually go 5 mins prior)
set end time (i usually go 5 mins after)
set channel number
set tape speed
exit by pressing clear/c reset
press t-set to activate the timer
the timer rec light should come on, the timer recording will not be active unless you press the t-set button
hope this helps
trin
Nov 16, 2007 | Sylvania SRD3900 DVD Player/VCR
Sylvania DV220SL8 DVD Player/VCR Logo
316 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
