My Frigidaire GLER331AS2 stopped drying. The drum turns but only cold air coming out the back. I removed the exhaust tubing and checked inside. The tube is clear of lint and dust. The front lint trap is also clean.
How can I isolate the problem to either the thermostat control or heating element?
My guess is it is the heating element. If it is that, how do I replace it? Going to the laudrymat is getting REALLY OLD.
TIA
Mike
Just use my simple GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hi
I
believe that everything else is fine rather it is the thermal fuse that is
located inside the rear panel to the exhaust duct that is bad and should be
replaced. If you want you can test this fuse for continuity and if it is bad
then it should be replaced, as it cannot be reset. If the fuse is fine then it
can be due to the control board that is bad and should be replaced.
Hope this helps...please post back for further assistance.
Daniel
SAME PROBLEM
GLER331AS2 BLOWS COLD AIR-Same as my problem. I checked all of the HI-Limit thermostats (Got continuity on all of them). Finally took the drum off - Thats when I saw the broken Heating Element. Took 15 min. to figure out and the part is about $60.00 average online or a parts store. Beats a $320.00 professional repair. Here is a link to a semi-exploded view. http://www.repairclinic.com/0100_20.asp
We're you able just to replace the element coil (spingl) only of did you have to replace the element housing?
