I just changed my power supply but when I start the PC its giving a OC failure error and then it shuts down by itself..This is a Gigabyte GA-945GM-S2 motherboard.
SOURCE: warranty
contact Gigabyte at www.gigabyte.com and ask them directly. As they do not post it in specifications.
Thanks,
Lee
SOURCE: Gigabyte GA-945GM-S2
Hi FRND,
check this link for the drivers which you want....
http://asia.giga-byte.com/FileList/Driver/motherboard_driver_lan_realtek_8111.exe
Enjoy...
Regds,
DRSS...
SOURCE: I have a Gigabyte GA-945GM-S2
You could use and USB keyboard to make these changes, to enter BIOS setup, please follow this steps: 1. When the power is turned on, press the button during the BIOS POST (Power-On Self Test) will (Use or to select a device, then press to move it up, or to move it down the list. Press
take you to the CMOS SETUP screen
2. Go to Advanced BIOS features.
3. Go to First boot device,
to exit this menu).
4. Press F10 to save your changes.
Hello here is the gigabyte homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2331&dl=1#manual
Try to download the manual.
The fault could be the power supply, try to renew that.
Try also to renew the thermal paste, between the cooling element and the cpu, and make sure the fan and the cooling element is clean for dust.
The fault could also be a defect ram module.
Any beep codes ???
Or blue screen ???
Good luck
