My dch3416 cable box display zero cable is hook up to it and its not showing anything now my wife did some reset how can i fix this
The box is missing all its channel line up info
best case sanario in 1/2 hour it will be done downloading it all again. too impatient to wait?
1) turn everything on as if it was working.
2) press power to turn off the cable box only (leave the tv on) and begin pressing ok or select over and over right away. may take a couple tries
3) you see a white screen with black text? select OOB and see if it says good or at least fair
4) select inband and see if it says good or atleast fair
5) if both good or fair wait; else make certain all cables are tight then check again
6) if they are NA or poor or anything of the sort call your cable operator
good luck
get a tivo ;}~
SOURCE: two tvs off Motorola DCH3416
If you have different input options on your TVs, you could run the second TV with the Y, Pb,Pr component outputs along with the analog audio from the STB. However, remember the STB will only support ONE output video format. So both TV will have to be set to the same video format (720p, 1080i, 480p, etc)
SOURCE: how to set a clock on a hd dual tuner dvbr dch3416
The clock should set automatically, synchronized with your cable provider's time. You can't change it, as far as I know. OR does it display the channel number and you want it to display the time? If so, go to your onscreen menu (home), choose setup, choose cable box setup, front LED display: current channel ----> current time.
SOURCE: looking for the meaning of error code on the CED
DUI is actually trying to display DVI on the box (the LED won't display the V and makes it a U). You typically see this error when your connected to your TV through an HDMI cable and the handshake for HDPC is lost. The box thinks your TV doesn't support it and wants you to change your connection. The error should go away once it finds that handshake. If you were using a different input on your TV, maybe a composite or something for a DVD, and then switch back it can get lost. If it doesn't clear right away try shutting everything off and turning it back on by turning on the TV first and then the box.
SOURCE: i received an error 4 code on my comcast supplied
Hi chestmcn. Here's how you reset your device to its defaults:
1. Make sure your receiver is plugged in, that it's connected to your TV, and that your TV is turned on.
2. Turn your receiver OFF, then press MENU on the front panel of the box. You will then see a menu on your TV.
3. Using either the up/down buttons on your remote control or the up/down buttons on the front of your receiver to navigate. Use the right arrow button to view the options for each setting.
4. Arrow down to the setting labeled "Restore All Defaults", then press the right arrow button to select that option.
5. Exit the menu and save your changes by pressing the POWER or MENU button.
For what it's worth, this issue may also be related to Comcast reference code error s0900, which means a disruption in service, usually temporary.
In case you run into more trouble with your receiver, here is a link to the user guide- http://www.motorola.com/staticfiles/Business/Products/TV%20Video%20Distribution/Set-tops/QAM%20Set-tops/All%20Digital%20QAM%20Set-tops/DCH3416/_Documents/Static%20Files/DCH3416_User_Guide_537529-001-c.pdf
I hope this helps. Thanks for using FixYa!
SOURCE: my son was playing
try it but try to look for a reset button in the unit or if you have the manual try to look for default setting.
Testimonial: "thankxx i well try !!!!!"
