Earthway "Earthway" Medium Duty Commercial Broadcast Spreader  2150 Logo
Posted on Mar 23, 2009
I have an Earthway EV N Spread EGB which I bought today, I need settings for Scott Super Turfbuilder with Halts crabgrass preventer, and for Scott Grubex, thanks
  • Anonymous Mar 14, 2014
    Settings to spread 1 bag pasture sward per acre
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
10981
Points
11
Here is a link directly to a pdf conversion table. It should solve your problems I believe.
http://www.earthway-outlet.com/pdf/spredguide.pdf
I want to put on Scotts Grubex with an Earthway Spreader EV-N-Spread what setting do I use?
This question would best be answered by calling Scotts directly at 1-800-543-8873. One of our associates would be happy to assist you further. Hilary @ Scotts
2helpful
I have a Scotts Turf Builder EdgeGuard Mini, and I'm using Ace turf builder (crabgrass preventer with fertilizer). What setting should I use???
I was just told by Scott's phone customer service (800-543-8873) that their TurfBuilder EdgeGuard mini can use the same settings as their "SpeedyGreen" broadcast spreader, if your fertilizer lists that one.
Apr 08, 2011 • Garden
1helpful
What is spreader setting for scotts southern turf builder on my earthway ev-n.
3/4 of all the way be sure to shut off before turning as u can clump fert in grass
12helpful
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
I have a Scott's rotary spreader that I use to spread Scott's Turfbuilder Plus 2 on the lawn. The problem is that the material collects on the rim of the wheels, and then dispenses in tracks on the lawn,...
It sounds to me like your grass is wet when you're applying, which is what the label calls for if you're trying to kill weeds. But is this wet grass maybe TOO TALL when you're pushing the spreader through it?
Next time, try mowing the lawn, then waiting 1-2 days before applying Turfbuilder Plus 2.
If anything were to work as anti-stick agent on the wheels, it would be Pam spray from your kitchen cupboard. Spray, let sit a while, then buff dry.
4helpful
I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
1helpful
Conversion Tables---- I have an Earthway broadcast spreader--need to know if there is a chart that converts Scott's settings located on the back of all Scott's fertilizer bags to Earth way settings?
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Wheel and axle broke
If the unit will not broadcast when pushed, try drilling a small hole through the inside of the wheel where the axle enters the wheel and insert a small cotter pin. This worked on mine.
136helpful
3answers
Need a quick way to convert Scott's settings to Earthway setting
add 10 - scotts turfbuilder spread at 4 on a scotts spreader should be on setting # 14 on an earthway spreader. happy yardening !
Top Earthway Garden Experts
Jay Finke
Jay Finke
john h
Are you an Earthway Garden Expert? Answer questions, earn points and help others
