To install themes on your l7 you will first have to download skinman and p2k drivers try the latest one (you can search for these softwares in google) In your phone change the default USB settings as data & fax connection then connect your phone to a usb port to which you had never conected your phone before then you will get a message that a new hardware is found select to "install now" then select "Install from a specific location" tick the "include this location in search" click "briowse" and select the p2k drivers folder that you had downloaded. For example "D:\Motorola System\p2kdrivers_2.9" Then click "next". It will install your phone. Then again you will get the same kind of message do the same for all until it says your phone has been installed and is ready for use. Now you have done half of the job. Now run Skinman the file list will be loaded. select install.You will get a message just select ok then browse and find the theme that you want to install then select open the theme will start installing. once you have added the desired number of themes select restart phone. now you are done.
How to install a themes for the mototrola slvr l7?
SOURCE: download themes
Hi
At the links below you will be able to find millions of themes and download them free of charge. just look around in the page and you will find what you are looking for .
http://www.mobile88.com or www.zedge.net
Hope this help.
rate this please
How to install theme in motorola slvr l7?
how to install themes n screensavers?
