SOURCE: I have a Kitchenaid Professional
I would give the "accept" to bestdarngood , if I were you..He has given the bets and complete solution there...That should work, if it doesnt. the the only recourse is a service center..
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
SOURCE: Agitator Shaft in Planetary
You need to carefully tap out the pin that goes through the gear and the shaft to remove it, You can find the parts list by entering your model number HERE.
