Question about TP-LINK TL-WA500G 54Mbps Wireless Access Point with Extended RangeTM Router
Unable to configure the repeater mode.
I have a basement in my home and i can't access the internet in the basement. I can use it on ground floor but the signals are not reaching the basement. My dsl is connected with tenda wireless router. I have introduced a tp-link wa500G wireless access point in the middle where it can catch the signals of the primary router and using it as a repeater mode to boost the signal, but its not working. Technically, dhcp is configured on my dsl, and primary tenda router through which i am getting automatic ip from the tenda router. The dsl interface is accessed through: 192.168.1.1 and tenda is accessed through: 192.168.0.1 while tp-link is accessed through: 192.168.1.254 Now the problem with tp-link wa500g is this that its default ip address is: 192.168.1.254 and when i set the wireless mode as repeater and enter the mac address of tenda router it doesn't work. I have also tried the bridge mode (point-to-point) on the tp-link but still no fruits. Please help.
    Sergeant:
  • 205 Answers
Tenda router is a very good network service provider, Tenda router has more than a million users across the country. It has provided high-speed internet, multiple sharing options, easy for connectivity with other devices and etc. But some time router users faced problem with this router service and not be solved to the issue, we are providing a Customer Service which is Tenda Router Customer Service Number. The customer contact by dialing a toll-free number +1-833-284-2444 and get immediate solutions.
When Tenda Router Not Showing Internet Light:-
Follow the given instruction and make problem free with your Tenda Router.
l First of switch off your modem & router
l Give it a rest and wait for a few minutes
l Switch On the modem & router
l A blinking light for internet connection will appear
l It will get stable in few seconds
l If you see the stable green light that means the issue is resolved.
When users get trouble for configuration contact our customer service number and get the solution for configuration, Tenda router service is wired and wireless service provider which solves the problem by taking just a minute and give the solutions. Customers also can get connected with Tenda Customer Service in case you find any issue.
Tenda Has genuine interface for his customer and providing guaranteed services. Some time customer wants to another technical service and they are can't take solution by a service number so we have an all technical solution platform which is providing any kind of services so visit our service number website and get solutions.
https://servicenumber.org/tenda-customer-service.html
Posted on Oct 16, 2018
SOURCE:
Where should you place router and modem for best signal quality in the basement or on 1st floor?
There are several schools of though on this. I just read an article about it on a site that had computer generated signal signatures. Here is a good article though: http://compnetworking.about.com/cs/wirelessproducts/qt/locate_aprouter.htm
Feb 25, 2015 | Motorola Computers & Internet
Tip
Using a network extender at home
Network extenders and repeaters work to extended the range of your wireless network. You don't have to live in a big house to need an extender, where I live houses are made of concrete which makes the wireless signals a little weak when you're not in the same room as the router. I had played with the idea of getting another router to put upstairs since the signal wasn't reaching from the office on the first floor to the bedrooms on the second floor. But setting up the router and the network was going to be time consuming and I was just trying to make the signal reach a little farther. That's when I discovered repeaters, I set up one repeater at the top of the stairs in my house where the signal began to weaken and ta da! The network now reaches the whole house at full strength and I didn't have to set up a new network.
on Sep 17, 2013 | Computers & Internet
I have a Toshiba Satellite L305D-S5934 notebook with Windows Vista Home Premium. I use Verizon wireless broadband to access the Internet. I can connect to the internet using their USB modems just fine, but...
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
akee_akee@live.com
Aug 17, 2011 | Toshiba Satellite A135-S4487 Notebook
Can't access internet
If you want to access the internet through your network carrier's data plan, bear in mind your network carrier's APN settings. Then, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access Point names'. Once there, press 'Menu > New APN', and fill in, at least, a 'Name' for it, and your carrier's data under 'APN', 'Username' and 'Password'. Then, press 'Menu > Save'. Press the back button as many times as required for you to reach the home screen you were in, before you started making these changes.
Hope it works for you.
Anyway, please, let me know if I can help you out any further, e.g. like accessing the internet through Wi-Fi
Regards,
Carlos
Jul 21, 2011 | Motorola Mobility Defy Cell Phone
I had a linksys wireless router that worked fine with my computer and samsung blue ray player. The router is in the basement (that's the only place the cable signal is srong enough for the internet) and...
I have the same setup. My router is in the basement right below as well. Nothing works better than direct wiring... if you can, consider drilling a hole in the floor (near the wall) behind the TV and BluRay, and run an ethernet cord directly from the player to the router. Ethernet cables are cheap as dirt online, and not too bad at big stores like Home Depot.
Apr 10, 2011 | Belkin (F5D8235-4) Wireless Router
How do I extend wireless coverage?
Extend the range of WiFi signals with Hardware If your router is placed on the ground floor of your home, the Wi-Fi signals will be very weak or may not even reach the basement computer or the printer upstairs. The situation will be no different if you work in a fairly large premises or if there are too many walls in the area.
In that case, here are some hardware device that you can consider to extend the reach of your Wi-Fi network:
wifi_repeater_thumb.jpgOption #1. You can attach a WiFi Repeater (also known as Wireless Range Expander) to your router and quickly expand the coverage of your wireless network without using any cables.
The Repeater should be placed within the range of your existing router and it will reflect the signals to other areas where the wireless reception was earlier poor (or totally absent). The Repeater can connect wirelessly to both routers and access points (see #3 below).
Option #2. (This is my current setup) You can get another wireless router and connect it to your existing router using an Ethernet cable. The advantage is that this setup comes pretty cheap and the Internet speed stays almost the same even for computers that are accessing the web via the new router.
You can get a 100 feet long Ethernet Cable (also known as Cat5 or LAN or RJ45 cable) for less than $10 and wireless routers start at $20. Here's a detailed guide on how you can connect two routers together.
Option #3. You also have the option to use an Access Point instead of a router to extend the WiFi range but that's often not required because Wireless Access Points can be more expensive than equivalent routers.
The other advantage with a router is that is has extra LAN ports so, in future, you can connect more wired computers for sharing files or you Internet connection.
Option #4. If you have an old desktop or laptop computer, you should consider adding an external (USB based) wireless adapter or upgrade the internal network card to improve the wireless reception (and thus Internet speed).
Jan 04, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
May 27, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Home heating issue! hot air is cold when it reaches top floor!
Just guessing, but I'll bet your 2nd floor duct work is in the attic, and uninsulated, wrapping all attic mounted duct work with R-13 insulation and sealing it with tape will help but there is still going to be a slug of cold air pumped into the upstairs rooms each time the furnace cycles.
Dec 11, 2009 | Better Living SPP High Efficiency...
2nd Computer in basement cannot access Internet
if your signal is low in there the best work around would be to lay a cat-5 cable up to the router, the wired connection would be faster and more reliable then a wireless, or buy another wireless router and put it closer to the basement than the first and wire the 2 routers togher with cat5 using the second router as a fancy switch.
Jul 02, 2009 | NetGear WGR614 Wireless Router
Open Questions:
TP-LINK TL-WA500G 54Mbps Wireless Access Point with Extended RangeTM Router Logo
139 people viewed this question
Top TP-LINK Computers & Internet Experts
 Mike M
Mike M
alex metro
alex metro
Pamela Bates
Pamela Bates
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
