Korg Pa800 Synthesizer Logo
Posted on Mar 23, 2009
Os system not loaded! hard drive was totally formated. PA800
My pa800 froze couldnt do anythiong so i switched it off and held onstyle play and media when powereed up, asked me to format so i formatted.
now cant load anything!
any solutions other than taking it to korg service.
can anyone help please..
regards
ernes
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
601
Points
Hi, have you solved this problem yet? If you have, share the solution with us please! :)
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
716
Points
2answers
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Korg pa800 256mb styles set
I wouldn't recommend doing that, because your OS system could freeze occasionally
Hello,i have a problem with my pa800,my display show:usb enable and os not prezent,turn off and put a os to a stick memory and turn on and push intro1,my display is black 75 procent and 25 work,and i cant...
If you are being asked to reload the OS, you will have to do that. SOME devices have trouble with USB sticks that are larger than some limit... that may or may not be specified. If you haven't tried reloading, try it with a USB stick no greater than 1GB... yes they are getting hard to find that small.
Whwn I turn on my PA800 it says Warning OTP Corrupted press media to continue!When I press media it starts to read and the instrument is working as usualy!?
One of the internal data for one touch has become corrupted. The best thing is to do a factory reset. Read your manual and follw the directions for a factory reset.
Find information of the procedure here:
http://korg-roland-synth-videos.blogspot.com/2009/07/pa800-system-data.html
7helpful
3answers
21helpful
4answers
Korg PA800. Ram Upgrade
The pa800 has a fixed amount of Ram at 64mbs and it is not physically possible to upgrade the Ram. The pa2x has a removable128mbs Module and that can be upgraded via a 256mb Module from Korg.
Keith [mrniceneasy - KorgForums]
3helpful
2answers
I have noise on ram samples
Korg Pa800 Synthesizer i have noise on ram samples Answer i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion,... (More) i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion, that happened 2 or 3 times, now its normal, but i think it may hapen again??? where is the problem, somebody says it is on motherboard? or its just ram overheating? since i install 2.01 os i noticed that its kinda warm in right display corner, can u help me???
Recording problem on pa800
It seems as though it may just be a sample issue.I have had this similar problem before,because each drum hit corresponds to a key on the piano.It could also be the program you are using to open it.
PA800 Instruments making noise
you have memory problem it cost $150 to fix it
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
