Question about Husqvarna Viking 1
Husqvarna Prisma 980 decorative stitch cassettes don't work
I've had my Husqvarna Prisma 980 sewing machine for more than 20 years. The decorative stitch cassettes (read-only) used to work, but now the machine won't switch from the default utility stitches to any of the decorative stitch cassettes (B, C, D). Everything appears to be working just fine in the default utility mode. Inserting the decorative stitch cassettes has no effect at all. It seems that either they're dead or the machine has lost the ability to read them. Any insight would be greatly appreciated!
  • josulim_fy Mar 24, 2009
    Many thanks, Kent! I would never have figured this out on my own. Using your solution, I was able to get all three of the decorative stitch cassettes to work.
    There are one or two 3/16" white squares on the lower end of each cassette. They correspond to the decorative stitch set on the opposite side of the cassette.
    I didn't have white-out or white paint. First I tried using 3/16" squares cut from the white border of a sheet of self-adhesive postage stamps...this was partially successful. Then I tried larger pieces (5/16" x 5/16")...this was 100% successful.
    Thanks again for your help!
  • Anonymous Mar 23, 2014
    Sewing machine works on default setting but cassette won't change setting and lights on circuit board are not on.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Kent
Posted on Mar 23, 2009
    Problem Solver:
I had tut double squares (one on top of the other) and it worked!
Posted on Jan 13, 2013
SOURCE:
Timing my prisma 980
Google (prisma)(980)(manual) without parens.
Jun 29, 2018 | Sewing Machines
Hi , I bought a Husqvarna Prisma 990 , but I don't have the part on the right side (front) that can be used for different stitches , where could I get it ? Also , can the machine work without it ?
check with a Husqvarna dealer or a sewing machine shop in your area, and you can even try ebay,, sewvacdoctor.com, a1sewingmachines.com and see if they can help you.. as far a saying if the machine will sew with out it,, I really can't say for sure..
Dec 16, 2014 | Husqvarna Sewing Machines
could be something wrong with a part or a cam. if the machine keeps doing the same problem, it would be a good idea to have it checked.
Apr 05, 2014 | Sewing Machines
Husqvarna prisma 980
since the sewing machine was given to you, it might be a good idea to have the sewing machine serviced to see if there is a problem with the reverse and stitch setting.
Aug 14, 2013 | Sewing Machines
Singer curvy
there could be something wrong with the cam that does the decorative stitches, you may want to have the machine checked..
May 27, 2013 | Sewing Machines
No utility stitches on my husqvarna prisma 980
Sound like you have an electronic problem.
Apr 11, 2010 | Husqvarna Viking 1
I have a viking 980. The decorative stitching does not work. I have no manual. Can any one tell me how to use these stitches. I think I may have just forgotten what to do.....:( Thanks! ChampionChicka
If the decorative stitches you are talking about are on the card that you insert into the machine, the problem can be that the sensor is not seeing the white squares on the bottom of the card itself. Take white paint or a white out liquid paper and "paint" the white squares at the bottom of the card but only the white squares. That will help the sensors "see" which card you have inserted. If that doesn't do it, your sensors are bad and they are not available. Make sure the paint is dry before you put the card back into the machine.
Jun 16, 2009 | Husqvarna Viking 1
Husqvarna Viking Prisma 980 pop then smoke, but still works
Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Apr 11, 2009 | Husqvarna Viking 1
Looking for Cassette B
I have a B card for the 1100 Viking are you interested?
Jan 28, 2009 | Husqvarna Viking 1
Sewing Machines Logo
2,038 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
MissFixIt828
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
