Computers & Internet Logo
Anonymous Posted on Jun 10, 2013
I don't have any task bars on my new computer
Anonymous
Level 3:
  • Master 2,878 Answers
  • Posted on Jun 10, 2013
Anonymous
Master
Level 3:
Answers
2878
Questions
0
Helped
488091
Points
8243
Try moving the mouse along the edges so it will unhide. Then drag it to where you want it and lock it in place.
Start tast bar disappears
Right click (hit right mouse button) on task bar and click to lock task bar and uncheck hide task bar. If you cannot right click on time before it disappears move pointer to the bottom of screen and it should reappear. Than follow above steps. If all else fails restart computer clicking on the F8 key repeatedly until start menu comes up , choose safe mode and when the computer starts up your task bar should remain in place, follow above steps to unhindered it permanently and reboot the computer it will start back up in normal mode and your task bar should be "fixed"
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
1helpful
The task bar disapeared
run you antivirus program
If CTRL+ESC didn't make it come back, then the program that displays the task bar most likely isn't running.
That program is often called the "Windows Shell", but it's really "explorer.exe". It's the program that not only displays the Taskbar, but also responds to the CTRL+ESC sequence.
The workaround: press CTRL+ALT+DEL to fire up the Task Manager. Now on the File menu, select New Task (Run...). Type in "explorer" and press OK. That should restart explorer and re-display your Taskbar.
hope this helps
Norton Task Bar
I don't think it supports firefox, but you dont need to load it because it still protects your pc anyways.
I have downloaded aviation software (APIC) to my hp iapq rx5910. The software is in the memory, but I cannot get it to work on the ipaq. Sometime, depending on what I am looking at, I get a message telling...
click on computer and see in the list for the c drive what is there
if you see aviation set up .exe
click on that and a tag that says run , click on run
It it is not there, click on the start icon (bottom lh task bar) and in the search bar under the programs section, type in --aviation
if it is on the computer it be revealed in the drive and file /folder where it is
click on it and click on open or run
I don't know what caused it, but my start menu, desktop and taskbar don't appear anymore after bootup. They appear only in safe mode. I've run antiviruses including the latest Dr Web CureIt and...
Hello it could either be that you have shortened the task bar or its on auto hidden type CTRL + ESC that will bring up the start/task bar right click the task bar and check the settings make sure that auto hide is turned off and that the task bar is unlocked and resize it if you can.
Hope this helps.
1helpful
How do i get a question mark on my keys instead of an e with a mark over it
Hi there, Your keyboard has been changed from English to French Canadian by the sounds of it! Go down to your task bar and on the right side look for the keyboard icon or two letters. Click on that icon, and select US instead of what is selected right now. You're looking for something like this if you're on XP - http://www.mirecki.us/computing/language/LangBar1.jpg It will be on the right side, to the left of the icons and the arrow to "show more". If you don't see the keyboard icon, right click on the task bar, go to Toolbars, and select "language bar". You should then see the keyboard or letters.
If you're still having troubles, comment back and I'll be sure to help! Cheers, Alex
2answers
Lifeframe webcam on an asus laptop, says camera is used by another program
Don't open two programs that uses webcam, for example: if you have skype application opened with video call you can use the webcam at yahoo messenger. make show application that requires one web cam features like video calling are online opened when needed.
if the is a hidden program that you sure to have close it that is still in process, then open the task manager and click on applications, you will see and end it process there, if the problem persist then restart the computer.
I own a Philips MP3 player (Go Gear 2GB) and don't have software for Win 7. The player came w/ a small disc that you use in a drawer, and I have an hP touchsmart with a CD slot. Don't think the...
I have a Go Gear 4GB. I just connect it to the computer. The first time, you will see a little balloon message at the bottom right corner, in the task bar, that will say "installing drivers".
Once this is done, simply open your explorer and you will see a new drive that probably even says Go Gear.
You can use this like a regular harddisk. Just copy all your mp3's directly to that drive.
Once you disconnect your device, the drive will disapear in windows, but the files will be on your Go Gear and you will be able to enjoy them.
Never used the software myself.
Hope that helps.
Grand Canyon Tech
Grand Canyon Tech
