Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Peavey bandit 112 reverb
All things connected works great other wise but reverb does not function any ideas
guitargeek89
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 01, 2010
guitargeek89
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1416
Points
5
Reverb died on my peavey as well, diagnosed the problem today, ordered the part, the IC DG211CJ or NJU211D, it controls the voltage going to the reverb tank.. well atleast this was my problem. cost to fix was roughly $5
Anonymous
Level 2:
  • Expert 84 Answers
  • Posted on Mar 23, 2009
Anonymous
Expert
Level 2:
Answers
84
Questions
8
Helped
38860
Points
272
It might just be the control knob. My fender's reverb went out and it was just the knob.
Gary Asher
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Feb 15, 2012
Gary Asher
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
3886
Points
14
Also check the reverb tank. I have one where the reverb springs actually broke, also check the connectors at the reverb tank and the amp chassis.
Peavey bandit 112
cracked solder joint, bad pot, dirty insert jack
Peavey bandit 112
have you tried using a foot pedal? Are you sure it is switching (green light turns red, etc?). On the lead channel are you turning up the gain all the way and the volume down?
Oct 12, 2013 • Music
2helpful
I NEED TO REPALCE THE TRANSFORMER FRO MY BANDIT 112.
It is unlikely the transformer is bad, Some of these have a thermal fuse in the windings. Usually failed components overload the power supply and blow the main fuse.
I'm trying to get a crunchy metal sound from my peavey 112 bandit. What should I set my controls to?
Overdrive is the key to the crunchy metal sound. The only effect on that amp is reverb.
You may want to consider getting an overdrive pedal to get the sound you want.
1helpful
Distortion on the lead channel is not working
The intergrated circuit is most likely gone out. Not much you can do, cost in repair is more than the amp. Check out the peavey vypyr, it's a great modeling amp for about $100.
1helpful
I have a peavey bandit 112 transtube guitar amplifier. Ive had it for nearly 15 years, but over the last few its become quite noisy when turned on even if nothing is plugged into the input. This is on both...
This has several vacuum tubes and those are suspect. Take a pencil and tap the glass of the smaller tubes to look for noise changes. You may have to take off the tube metal shield to do this.
If you have got 15 years of life from the tubes that is great. Also suspect are electrolytic filter caps.
If you are not electronically adept, take it in for repair.
 Grubhead
Grubhead
SmartAviator
SmartAviator
