LG 42LB5D 42 in. LCD Television Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg 42lb5d base stand
Hello, do anyone know where i can get the base for the LG 42LB5D?
  • 1 more comment
  • tjace2000 Apr 14, 2009
    thank you
  • Anonymous May 23, 2009
    cant
  • Anonymous Mar 15, 2014
    I have a LG 42LB5D 42" all 3 of the HDMI outputs do not work. I believe we had a power surge. Is there anyway to fix this problem? Thanks
Anonymous
Level 2:
  • Expert 298 Answers
  • Posted on Mar 31, 2009
Anonymous
Expert
Level 2:
Answers
298
Questions
Helped
304330
Points
615
Here's a link to order the original LG base stand assembly for this model (42LB5D) from a major parts distributor. Please note, you would have to verify the complete model number of the unit as their are 2 versions availible (there should be either a C or F at the end of the model #):
LG 42LB5DC Replacement Part Base Stand Assmebly
LG 42LB5DF Replacement Part Base Stand Assmebly
What are the vesa wall mount specs for the lg 42lb5d?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Menu codes
LG-42LB5D-UC Service Manual and Repair Guide
LG 42LB5D UC Service Manual and Repair Guide Download Manuals Technical
Official factory service, repair and workshop manual. This service and repair manual is used by the Certified LG Technicians. It will help you to troubleshoot and repair your television!
Please note this is the OFFICIAL service manual in PDF format, no scanned in or bootlegged copy. This manual is made in the highest resolution, so when you print the pages you need it is all in great quality.
LG Model 42LB5D T-Con Board Fasilure
It will be best to use a new genuine T'Con board, rather than a used or repaired one. Contact the authorized service center for LG, to buy it genuine T'Con board. Usually, there is no other adjustments should be done when replacing the T'Con board, provided, with its genuine T'Con. The comes to it price. T'Con board will cost according to brand to brand. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
What size are the base stand screws for LG 42lb5df
I am also looking for screws for my LG 42LB5DF-UC, can someone help?
Hi, Do anyone can tell me where i buy a LCD scree replacement for my LG 42LB5D???
it is a better way if you avail the service from the "LG's Authorised Centre".
Best of Luck !
Pawan Verma.
LG 42LB5D ON and OFF randomly
A problem with modern flat screen tv's is the power supply capacitors.they dry out and cause various problems , like stuck in stand by, slow to come on, etc. You can spot them usually ( they bulge out and deform) but really I dont recommend this job unless you have had experience in soldering.
It could be a loose connection in the power supply though.
Hope this helps
pete
LG 42lb5d has audio but no picture, but this only happens sometimes when I turn it on. Sometimes it is fine. When it does happen i just turn tv off then on again until it fixes it. I had this tv serviced...
They may have missed out the power supply circuit. There may be loose solders or bad parts. You may have eliminated other parts which may have caused the problem when the service center replaced the parts. Inspect those that you still have remaining for leaking capacitors, loose parts or loose solders.
Remote control of LG 42LB5D
Here's a link to order the original LG remote control for this model (42LB5D) from a major parts distributor. Please note, you would have to verify the complete model number of the unit as their are 2 versions available (there should be either a C or F at the end of the model #):
LG 42LB5DC Replacement Part Remote Control
LG 42LB5DF Replacement Part Remote Control
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
